I know 93 octane post. But, hear me out.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SWB Tacoma, Jun 16, 2018.
  1. Jun 16, 2018 at 1:00 PM
    #41
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
  2. Jun 16, 2018 at 2:11 PM
    #42
    mackb
    mackb Well-Known Member
    2016 Tacoma Limited
    3 inch suspension Lift, Fab Fours front bumper.
    What about catalytic converter life span?
  3. Jun 16, 2018 at 2:14 PM
    #43
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    You need higher octane for higher compression engines. Look at the compression ratio of engines with higher octane requirements and compare to yours.
  4. Jun 16, 2018 at 2:15 PM
    #44
    M-cameron
    M-cameron Well-Known Member
    2017 Tacoma
    Going to be virtually unaffected by octane....
    Theoretically if you are running a super high octane for an engine that doesn’t require it, you are going to get unburnt fuel passing through the engine, which would damage the cat.... but standard pump fuel won’t have these issues
  5. Jun 16, 2018 at 4:30 PM
    #45
    SWB Tacoma
    SWB Tacoma [OP] Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    87 octane requires less timing to burn under cylinder pressure.
    93 octane burns at hotter cylinder pressure so your computer advances timing to accomplish that task.
    More timing in an engine creates a more responsive engine.
    GR8APE likes this.
  6. Jun 16, 2018 at 4:39 PM
    #46
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Don't really care what some stupid video says, my Taco runs a lot better on 89-93 octane.
  7. Jun 16, 2018 at 4:54 PM
    #47
    SWB Tacoma
    Arkansas
    I didn't watch video either. Don't matter. I know what my butt dyno tells me.
    GR8APE likes this.
  8. Jun 16, 2018 at 5:30 PM
    #48
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    You boys git out of here with your "science" and your fancy book-learnin'!
  9. Jun 16, 2018 at 5:32 PM
    #49
    Tacotickler
    Tacotickler Active Member
    16 TRD sport DCSB 4x4 6MT
    Reading this thread thinking I wish fuel was that price again...damn u canada its about $4.76 regular here and much higher in some parts of the country. No way in hell am I pumping supreme.
    ....just buy a cai and exhaust if ya want better mpg and hp...jeezz everyone knows that trick.. its well documented :spy:
    taco2010trd likes this.
  10. Jun 16, 2018 at 5:41 PM
    #50
    M-cameron
    2017 Tacoma
    there are ricers everywhere that will swear to you they can feel a difference after theyve added a cold air intake and a fart cannon........doesnt make it true.
    we spend all this money on mods, and our brain will straight up lie to us to make us feel like we havent wasted a bunch of cash.
    only if your car is tuned to take advantage of it.
    its not as simple as just pouring in higher octane and getting better performance.
    if your car is "adding" timing due to higher octane, its only because it was pulling timing before, which means you have an issue.
    do you people honestly believe if simply adding higher octane gave any performance increase, that people doing track days, or weekends at the drag strip wouldnt be filling up with 110 and running?
  11. Jun 16, 2018 at 5:53 PM
    #51
    Sungod
    Sungod Well-Known Member
    St Augustine
    This claim that you get better mileage out of higher octane is nonsense. There is no more stored energy in a gallon of 87 octane vs 93. In some cases your performance will suffer because it doesn't burn as clean. Also an interesting point, E15 is 88 octane.
    hiPSI likes this.
  12. Jun 16, 2018 at 5:58 PM
    #52
    SWB Tacoma
    Arkansas
    No higher octane burns at a higher rate. Which allows you to increase timing. Timing is what increases engine performance.
    Speaking of drag racing. I've done it for 30 years. Advanced timing increases low end. An takes away from top end power. Retarded timing decreases low end power an adds to top end power.
  13. Jun 16, 2018 at 6:15 PM
    #53
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Is this also a safe space to discuss cold air intakes?
    CMD-KY and Tacotickler like this.
  14. Jun 16, 2018 at 6:22 PM
    #54
    SWB Tacoma
    Arkansas
    I don't know about cold air intakes. But cooler forced air induction makes more HP. Can not argue against turbos and blowers.
  15. Jun 16, 2018 at 6:26 PM
    #55
    M-cameron
    2017 Tacoma
    Jesus Christ.... Y'all are gonna be talking about how much HP you gained from a cat back exhaust next....
    Or do they "need a little bit of back pressure" to run right?
    SWB Tacoma[OP] likes this.
  16. Jun 16, 2018 at 6:29 PM
    #56
    SWB Tacoma
    Arkansas
    Nope open headers run better. Bolt a section of pipe on it an cut it where it changes colors. That varies dependent on engine. Usual cut them about 18" or so from end of header.
  17. Jun 16, 2018 at 6:30 PM
    #57
    SWB Tacoma
    Arkansas
    I'm going bed. Getting up early in morning. :burnrubber:
  18. Jun 16, 2018 at 6:37 PM
    #58
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I wish we had 85 octane here as that's what I would use. Since we don't I use 87.
  19. Jun 16, 2018 at 8:23 PM
    #59
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You won't get better mpg (impossible) but it will give you a bit more power... not from the fuel itself, as a gallon of gas has generally the same amount of energy no matter what octane rating, but because the truck will change timing because of anti knock properties in the fuel and give you a bit more power.
    Now, go calculate what the difference in cost is for you for a year at 87 vs 93 octane. Simply the difference in price times the miles driven times number of years you will drive it... and tell me if it's worth it for about 10 hp.
  20. Jun 16, 2018 at 8:37 PM
    #60
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    http://www.new-cars.com/2016/toyota/specs/tacoma.html
    Our trucks have pretty high compression, 11.8
    Sagebrush and SWB Tacoma[OP] like this.
