I know it is cold but there is no way this normal for a clutch right?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ahlerscurtis, Jan 4, 2018.
  1. Jan 4, 2018 at 6:06 AM
    ahlerscurtis
    ahlerscurtis [OP] Well-Known Member
    2019 Quicksand TRD OR DCLB
    I know the 2nd gens have sticky clutches when it is cold outside. But my clutch is now really sticky and I feel like it is not normal or safe to drive with.
    The clutch stays this way for about 15mins while driving, until the engine gets really hot.
    This is my second manual truck, I ever experienced this before with my first manual.
    Any chance there is moister in the lines and that is what is freezing? The truck is still under warranty, is it worth taking it to the dealer? or is these just the way tacomas are.
    Thanks
    -Curtis
  2. Jan 4, 2018 at 6:28 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    My clutch pedal was squeaking and I got a free updated pedal/masterful assembly installed at the dealer under warranty
  3. Jan 4, 2018 at 7:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Flush the clutch fluid perhaps?
  4. Jan 4, 2018 at 7:06 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the gear oil is cold and thick and not up to the operating viscosity until it heats up to proper operating temp., this is normal for all manual transmissions when subjected to below freezing artic temps.
  5. Jan 4, 2018 at 7:15 AM
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
  6. Jan 4, 2018 at 7:17 AM
    Pigpen
    Dan
    Northwest Montana
    At -20F mine doesn't give me trouble :notsure:
  7. Jan 4, 2018 at 7:30 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    What does gear oil have to do with this? You don't use gear oil for hydraulic fluid and your transmission function is unaffected by the movement of the clutch in this scenario...?
    DGXR, wilcam47 and burlyb like this.
  8. Jan 4, 2018 at 7:32 AM
    Pigpen
    Dan
    Northwest Montana
    The clutch operates on brake fluid, not gear oil.
    wilcam47, Synergy001 and BillsSR5 like this.
  9. Jan 4, 2018 at 7:35 AM
    BillsSR5
    bill
    2014 SR5
    the dude says he has is sticky clutch due to being cold, my experience with manual trans trucks/cars is that the clutch isn't sticky it more so the engine and trans aren't up to operating temps so it feels like the gears aren't shifting as smoothly as they would when the temps are above freezing, because the gear and engine oil is still thick from the extreme cold, the viscosity in the oils thicken until operating temp is achieved 5-10 minutes of driving then it feels normal
  10. Jan 4, 2018 at 7:38 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    Sure, but if you watched the video to see he's talking about the pedal movement being sticky when he's not moving, just disengaging/engaging the clutch. If he said it was hard to shift, I would get what you mean.
  11. Jan 4, 2018 at 7:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's not the clutch that is sticky, it's the clutch hydraulics.
    Is it full of fluid? Not impossible for the master to fail. And certainly to be sluggish.
    I'm assuming its fairly low miles and never been serviced.
    Exercise that warranty.
  12. Jan 4, 2018 at 7:43 AM
    BillsSR5
    bill
    2014 SR5
    if im not mistaken the OP says that his truck stays sticky until after 15 minutes of driving until it warms up then I assume it functions properly, all in all extreme colder temps have an effect on how mechanical parts function, until optimal operating temp has been achieved. also the dude with the vid stated it was 6 degrees F this is far below what optimal temp should be to function as normal as if it were 60 degrees F you cannot expect it to function the same initially till the vehicle warms up
  13. Jan 4, 2018 at 7:45 AM
    Pigpen
    Dan
    Northwest Montana
    In really cold temps I definitely have sluggish shifting from cold gear oil. The Redline MT oil helps.
    This sticky pedal issue is a whole different issue. Sticky clutch threads pop up every winter, just like the squeaky clutch threads do every summer. Hit the pivot and the rubber bushing at the firewall with a little lithium grease spray. It should solve both. If not, do a full brake fluid flush (including the clutch) - it should be done every 3 years anyway.
    Torspd and DGXR like this.
  14. Jan 4, 2018 at 7:47 AM
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    Yes, and again, that has nothing to do with the engine or transmission themselves. His clutch hydraulics have an issue, be it moisture, air, or other contaminants in the hydraulic fluid, or a something else that is causing it to stick in the system (master is gummed up with something, pedal grease is frozen, or he has a gnome in the clutch that is a bit slow moving until his shop gets up to operating temp). The transmission fluid being cold has nothing to do with a sticky clutch pedal, they are independent. The general heatsoak off the engine is loosening up whatever the issue is, but I assure you it isn't the transmission oil...
  15. Jan 4, 2018 at 7:50 AM
    BillsSR5
    bill
    2014 SR5
    yes this makes sense to hit the pivot points on on the clutch pedal with lithium grease , and having cold gear oil doesn't help either
  16. Jan 4, 2018 at 7:52 AM
    Pigpen
    Dan
    Northwest Montana
    Just for the record (for comparison's sale):
    We've had quite a few mornings this year that were colder than -10F. I haven't used my engine block heater yet. I don't have this problem.
    This issue is not normal, and has potential to do mechanical damage to your truck.
    If it's under warranty, have Toyota fix it.
    DGXR likes this.
  17. Jan 4, 2018 at 7:53 AM
    BillsSR5
    bill
    2014 SR5
    if im not mistaken the title of the thread is I know its COLD but theres no way this normal for a cluthch right? The key word here is COLD and the second clue is that after 15 minutes till it gets HOT then it works Ok so temperature plays a key part in the OPs issue. Yes or No?
  18. Jan 4, 2018 at 7:55 AM
    Pigpen
    Dan
    Northwest Montana
    Temperature is exacerbating the symptoms, but not causing the problem. That's the real point being made, Bill.
  19. Jan 4, 2018 at 7:55 AM
    BillsSR5
    bill
    2014 SR5
    I would take it in then, if its on and of again and temp doesn't matter more of a mechanical or clutch adjustment issue
    Pigpen[QUOTED] likes this.
  20. Jan 4, 2018 at 7:57 AM
    BillsSR5
    bill
    2014 SR5
    true, kinda hard to believe a 2015 6 speed has hydraulic clutch issues but its possible, I would take to the dealer let them test it out
