I know its not a Tacoma BUT.....
Discussion in 'Technical Chat' started by Stillfly199, Jun 1, 2010.
  1. Jun 1, 2010 at 3:20 PM
    Stillfly199
    Stillfly199 [OP] ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I have a 2010 FJ as most know. Its an Auto, 4wd, 2800 miles, bone stock. I have had it in 4lo before with no problems. Now when I tried to put it in 4wd last night it went into 4hi just fine. Put it in Neutral to shift to 4lo and when the transfer case went into N and tried to put it into 4lo it started grinding and wouldnt go into 4lo. Tried to take it back to 4hi and started grinding again. It has a manual lever for the transfer case. Anyone have any ideas on whats wrong? The dealer I got it from is 3 hours away.
  2. Jun 1, 2010 at 3:23 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    did you try shifting it back into low? Mine did that once when I first starting using the 4wd but went away the more I used it [you know, when I was doing some hardcore mallcrawling]. I tried shifting it, it grinded, i moved forward, then tried again and it went in fine.
    I just saw a post on the fj forum too about someone having trouble shifting into 4wd and many, if not all, the responses consisted of similar experiences with a new vehicle. They said time and use will allow a more smooth shifting.
  3. Jun 1, 2010 at 3:24 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    And damn you rack up miles quick! Mine barely passed 1k. Did you get the 2 yr maintenance program? [you should have]
  4. Jun 1, 2010 at 3:30 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Ya, I think I got that program, I think it was the incentive. I tried driving it again and what not. The thing is is that I have to shut it off and shift it into 2hi in order to get it moved. Its not just a little grinding, it is full on grinding. I know the local dealer wont be to helpful because I didnt buy from them.
  5. Jun 1, 2010 at 5:38 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    So is it still in 4L ??? or you managed to get to 2WD?
  6. Jun 1, 2010 at 5:39 PM
    BlueT
    NorthEast
  7. Jun 1, 2010 at 5:44 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    when you shift from 4hi to 4lo you should be making the move in a smooth motion, meaning no stop in between 4hi and lo. when you leave it in neutral for any amount of time the output shaft of the tranny will begin to rotate causing grinding in the t-case. easier with a stick cus there is no connection between the engine and tranny threfore no turning of the output shaft, autos are constanly in motion, even in neutral, but in neutral there is just enough power getting thru to turn the output shaft if it is allowed to do so. sorry for the long post, and hope it makes sense, good luck!
    --mike
  8. Jun 1, 2010 at 5:49 PM
    mick478
    Bott
    Stockton, CACA
  9. Jun 1, 2010 at 6:33 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Thanks man, I didnt know that. I went out and tried it and worked without a single grind. Thanks a lot man.
