I know there a lot of FLIUD FILM threads
Discussion in '1st Gen. Tacomas (1995-2004)' started by JC34X4, Jan 28, 2020.
  1. Jan 29, 2020 at 7:35 PM
    #41
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I tested and used LPS3 on raw metal surfaces, pre-rusted surfaces, and painted surfaces. It 100% seals moisture out while still allowing the metal to release any moisture previously in the metal. I have seen in both rainy, humid and magnesium chloride salt condtions all of the above surface conditions remained the same as they were the day I coated them with LPS3 I wish I knew about this product years ago it would have saved me tens of thousands of dollars. The one and only negative is LPS3 is extreamly hard to remove and will require an industrial solvant and paint scraper.
    A lot of people love this for their frames and undercarriages apparently. I checked the reviews :D
  2. Jan 29, 2020 at 7:47 PM
    #42
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    :thumbsup::thumbsup:
    Thanks, good to know. Just one question, Does Jay know about it ?:thumbsup:
    High Noon likes this.
  3. Jan 29, 2020 at 8:27 PM
    #43
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    If you want something that will prevent rust and won't wash off...Cosmoline. It has been used since the late 1800s. It's that thick waxy stuff you find on military surplus guns. It won't wash off. In fact, it's a bitch to get off. I don't know if it is compatible with rubber and plastic though, I'm guessing not since it's petroleum-based. I also don't know if it will wick either.
    GQ7227 and High Noon like this.
  4. Jan 29, 2020 at 9:21 PM
    #44
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    I forget what it is honestly but it's on the Amsoil website.
    As for how long it lasts in splash areas, I don't think I've ever resprayed it during the winter. It seems to hold up throughout. I also don't drive mine in the snow unless I have to. If we get a decently warm day I'll spray the cab mounts again just because my cab mounts are chopped.
    Overall, it holds up really well and I'm happy with how my frame looks. I first wash the underneath really well. Then I paint it flat black and then the Amsoil HDMP. Let it sit a few days.
    GQ7227[QUOTED] likes this.
  5. Jan 29, 2020 at 9:24 PM
    #45
    GQ7227
    GQ7227 mw survivor
    J A Y
    The only fun thing to do in Nebraska and Iowa is to drive in the deep sloppy snow before they plow and salt the roads!
    @Shellshock what do you think
  6. Jan 29, 2020 at 9:29 PM
    #46
    GQ7227
    GQ7227 mw survivor
    J A Y
    IDK
    Been driving for 3 days straight and time to ponder what to do now
  7. Jan 29, 2020 at 9:40 PM
    #47
    GQ7227
    GQ7227 mw survivor
    J A Y
    I should give it another shot then
    Pretty sure you are in the near exact climate as I am
    But why two coats a year winter is not that long here!?
    Do you coat body panel spots with ff too?
  8. Jan 30, 2020 at 4:46 AM
    #48
    1997tacomav6
    Denver
    Lol, was ok, I didn’t know your fame was like a sponge filler with film fluid.
    I haven’t use that stuff before or seen it applied.
  9. Jan 30, 2020 at 5:30 AM
    #49
    JC34X4
    JC34X4 [OP] Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    No one is in a panic. Just looking for peoples opinions on the BEST WAYS to do something that others have experienced. Isn’t that what this TW is for??? Stop trolling! You got some good input give it! Other then that
    No offense....
    cgs2k2 likes this.
  10. Jan 30, 2020 at 5:33 AM
    #50
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    Easy to apply and cheap. My buddy cut out the rot on my frame and welded in new metal so its an easy rust prevention especially since I wasn't able to paint the metal on the inside of the frame.
    I hook up my abrasive blaster to my compressor, load in a ton of FF and cover the exterior of the frame. Then I load the inside up at every angle I can until it starts coming out of the drain holes.
    I haven't done anything other than the frame, fuel tank skid plate, and rear axle.
  11. Jan 30, 2020 at 12:01 PM
    #51
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Nah, we painted stuff with it and left it outside at the refineries here on the Gulf Coast. It's salty, humid. Everything rusts here except exotic alloys like Inconel. LPS actually got harder the longer it stayed in the sun.
    I can't guarantee it's still made as well as the '90s.
