I Krown'd did you ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lawrenccar1, Feb 19, 2016.
  1. Mar 28, 2016 at 9:59 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Agreed, depending on the mod level of your truck, it may be desirable to have other areas of the undercarriage coated. In my case, I have Icon shocks with exposed shafts, All-Pro control arms with exposed uniballs, etc., so it was important the coating didn't get on them. My Budbuilt skid plates are powdercoated and mounted with stainless hardware, so they don't need to be coated either.
    Note the Krown warranty excludes "mechanical parts". The coating will probably improve the corrosion protection for those parts, but they won't be warrantied.
  2. Mar 28, 2016 at 10:32 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    Yea, the warranty only covers perforation where the paint isn't broken or something too. So a scratched/chipped area isn't covered anyway. I don't really care about the warranty honestly. I hope it provides enough protection that I just don't have to worry about rust.
  3. Mar 28, 2016 at 10:34 AM
    StevoNB
    NB, Canada
    Where exactly is "the belly of the beast" anyway? Hahah. I live near salt water and they put down a shit ton of road salt in the winter too. I had to do something, Krown seemed like the best option for me.
  4. Mar 28, 2016 at 10:48 AM
    sumncguy
    sumncguy Well-Known Member
    Hurdle Mills North Carolina
    2015 Access Cab SR5 V6 4X4 AT
    As stock as they come.
  5. Mar 28, 2016 at 11:08 AM
    lawrenccar1
    lawrenccar1 [OP] Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    for what its worth krown also states it lubricates/protects gas lines, brake lines, electrical connections, mechanical connections,etc..
  6. Mar 28, 2016 at 11:17 AM
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    I spray old engine oil on my chassis. 0 rust except on my ome shocks.
  7. Mar 28, 2016 at 2:21 PM
    KenLyns
    Belly of the Beast
    I'm in the Great Lakes region. They put down a shit ton of road salt in the winter. The parking lot at my work is right next to a salt dome, so they really overdo it and turn the tarmac white whenever temperatures dip below freezing:
    Taco Centipede 2: Salt Bath
  8. Mar 28, 2016 at 5:47 PM
    StevoNB
    NB, Canada
    Yea the white pavement is pretty common during the winter. Are those trucks actually touching?
  9. Mar 28, 2016 at 10:34 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Might be a mating ritual.
    StevoNB[QUOTED] likes this.
  10. Mar 29, 2016 at 3:48 AM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    This reminds me - I'm due for my second Krown treatment.
    I'm sure they tell you at the shop, but park on the street(maybe even a few houses down)for a few days after. She drips quite a bit.
    I'm confident Krown will keep the inside and outside of the truck rust free and actually extend life of sensors, lines and what have you. At 150 a year, it's cheap peace of mind and you'll see that in the resale value as well.
  11. Aug 31, 2018 at 8:22 PM
    fgeorge097
    fgeorge097 Well-Known Member
    Northeast
    2018 OR AT
    How is your krown treatment holding up three years later? Any issues with rust, or the rubber seals coming off? Everything OK when you go for maintenance?
  12. Sep 1, 2018 at 7:49 AM
    ozzy73
    ozzy73 Active Member
    Milton, Ontario
    2005 Toyota Tacoma TRD 370 KM
    After frame replacement I have been applying it annually. Holds up well through they year. I wash truck regularly in winter and still good by next fall. $130 cost in Ontario for repea customers.
  13. Sep 1, 2018 at 7:50 AM
    fgeorge097
    Northeast
    2018 OR AT
    Thanks, any issues with rubber peeling? Do you let them spray under the hood?
  14. Sep 1, 2018 at 8:07 AM
    ozzy73
    Milton, Ontario
    No rubber swelling or peeling. Yes they sprayed the sides of engine bay and also underside of hood. This stuff creeps everywhere which is nice. Messy for a few months after the application, lots of drips. We have gravel driveway so no biggy.
  15. Sep 1, 2018 at 8:13 AM
    #35
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    Look up the concept of a "sacrificial anode"
    Basically, it means 'what's easiest to oxidize, will oxidize first'. In other words, 1st gen Tacomas have mint body panels because the oxidation consumes the frame first. The frames are so insanely easy to rust, that the body panels will have absolutely zero rust until the entire frame is consumed.
    This is why domestic trucks have their entire body rusted out, but almost a pristine frame. Gotta weigh which one is worse...a Dodge with the rockers, cab corners, and bed completely rusted, but a solid frame, or a Toyota with a mint looking body and swiss cheese frame?
    Sacrificial anodes are used everywhere, from ships to hot water heaters. You put out some 'low hanging fruit' to protect the main body. You know how hot water heater companies can offer a 15 yr warranty vs a 10 yr warranty? They just put a bigger piece of anode in the bottom! As soon as it gets consumed, your heater rusts out in like 3months.
