I let my dad drive my truck and now it’s making this awful sound.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Apr 12, 2019.
  1. Apr 12, 2019 at 10:31 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
  2. Apr 12, 2019 at 10:42 AM
    eon_blue
    Azusa, CA
    Do you have uniball UCAs? I would start by lubricating the uniballs on those.
    And don't use silicone spray, use a dry lubricant like Tri Flo or WD40 Dry Lubricant (not the regular WD40).
    Silicone spray will attract a ton of dirt and grime and make it way worse.
    lynyrd3 likes this.
  3. Apr 12, 2019 at 10:43 AM
    jardoo
    Beirut, Lebanon
    Yeah I regularly use dry Teflon lube on them. I’ll try that, thanks.
    eon_blue[QUOTED] likes this.
  4. Apr 12, 2019 at 10:46 AM
    jardoo
    Beirut, Lebanon
    Ok it didn’t work. Also just found out it’s only the front left wheel.
  5. Apr 12, 2019 at 10:46 AM
    eon_blue
    Azusa, CA
    I made the mistake of using silicone spray on the spherical bearings in my lower coilovers and it worked well initially, but sealed their fate much faster in the long run because it just gunks up and holds all the dirt/road grime that touches it.
    Dry lubricant on the spherical bearings in the lower eyelets of your coilovers might help too, if you have those.
    If you have have stock suspension or 5100s, etc, then you won't have those bearings.
  6. Apr 12, 2019 at 10:48 AM
    eon_blue
    Azusa, CA
    What kind of front suspension do you have?
  7. Apr 12, 2019 at 10:48 AM
    jardoo
    Beirut, Lebanon
    I have icon stage 5
    Got a picture of where I should spray?
    Sorry, I’m legit retarded and drunk.
  8. Apr 12, 2019 at 10:48 AM
    jardoo
    Beirut, Lebanon
    Icon stage 5
  9. Apr 12, 2019 at 10:49 AM
    eon_blue
    Azusa, CA
    No worries, I don't really have a pic but the bearing is at the bottom of the coilover where the bolt goes through. Just push the straw from your dry lubricant into that area and spray away.
  10. Apr 12, 2019 at 10:50 AM
    eon_blue
    Azusa, CA
    Also you might have to drive it a bit after you do this to get the lubricant to work itself into where it needs to be, the sound might not go away instantly
  11. Apr 12, 2019 at 10:54 AM
    jardoo
    Beirut, Lebanon
    Great thanks.
    Just sprayed some and turned the steering a little and I think it sounds a little better. I’ll drive it later when I sober up.
  12. Apr 12, 2019 at 10:56 AM
    Oldbugr
    Oldbugr Active Member
    2019 DCSB TRD Offroad
    That sounds like your tire is wet and just making the noise on your floor surface?
  13. Apr 12, 2019 at 10:57 AM
    Oldbugr
    That brick surface.
    jardoo[OP] likes this.
  14. Apr 12, 2019 at 10:59 AM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Spray some between the tire and the floor.
  15. Apr 12, 2019 at 11:08 AM
    jardoo
    Beirut, Lebanon
    lol...
    If I drive off later and it’s the floor I’m going to just sell my tacoma. I don’t deserve it.
    Few months ago I pulled the transmission plug while changing my oil drunk. Had to tow my truck to Toyota.
  16. Apr 12, 2019 at 11:14 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Check yer nuts....(on the wheel)
  17. Apr 12, 2019 at 11:26 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I had this exact same sound / Issue all last summer, it drove me nuts!!. I coudnt find the source, when I took it in for an alignment I asked them to check it out because I couldn't figure out where it was coming from. After I got my truck back it hasn't happened since and they said they "didn't find anything" so I am curious as to what fixes this.. I just have a spacer lift no aftermarket UCA ect. When I was trying to listen for it, it sounded like it was coming from the knuckle area, like maybe a dry ball joint?.. I also tried to spray pretty much everything that moves on that front suspension without much luck.. I wish i knew what that shop did because it hasn't returned since..
  18. Apr 12, 2019 at 11:28 AM
    jardoo
    Beirut, Lebanon
    That sucks bro. I feel your pain right now.
    My sound is coming from the wheels area down low.
    Crodell6 likes this.
  19. Apr 12, 2019 at 1:18 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    I had a similar noise after a wheeling trip. King suspension/Camburg UCAs. I would be parked, turn the wheel left and right and hear a squeak.
    I lubed my uniballs with Tri-Flow AND greased my UCA bushings with superlube. I feel like the superlube on the bushings is what stopped the squeak. Make sure you loosing the UCA Bolt before greasing.
  20. Apr 12, 2019 at 1:19 PM
    jardoo
    Beirut, Lebanon
    I’ve never greased my bushings since they’ve been installed. I’ll try that.
