i love my new toyota 2014 w/tow packg
Discussion in 'New Members' started by bchbm1966, Sep 18, 2019.
  1. Sep 18, 2019 at 1:30 PM
    bchbm1966
    bchbm1966 [OP] New Member
    2014 toyota tacoma w/towpckg
    I just went to look at the 2014 toyota tacoma couple weeks ago ended up buying it it looked like new and i got the certified toyota warranty, All the other trucks i looked at had high miles and stained seats no warranty etc. so i paid a lil xtra low miles and warranty i didnt want something with out warranty i love to go for drives in the mountains and have piece of mind that im not going to break down. I allready drove it from calif to colorado no problems but im looking to buy a travel trailer. The manuel says i can tow up to 6400 pounds but would like if someone here can tell me what a safe weight trailer should weigh. The rv guy said to get a travel trailer around 5000 lbs i dont want to max out the towing wieght. Does this sound about right? and maybe i should add on some xtra accessories on the truck for towing?
    buckhuntin-tacoma and irayfz6 like this.
  2. Sep 18, 2019 at 1:41 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Welcome and congrats on the new truck. 5k would be a good mark to try and stay under depending on the conditions you are towing in. Keep in mind the altitude and mountains and adjust that if you are in those conditions. Also keep in mind what other weight you will have in and on the truck and in the trailer. Try to keep that at 5k or under and you should be fine. Know you MPG will take a steep hit while towing but that is the case with most anything and these trucks are not well known for great MPG anyway. Probably will want to replace the leaf packs in the back or add an AAL or 3 leaf pack to them. Pretty simply and does a good job but the factory rear springs are junk.
    To be clear I would consider 5k the max with what is in the truck and trailer, including the trailer. Even then it will be a bear depending on conditions.
  3. Sep 18, 2019 at 1:41 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    5000 pound trailer plus gear plus other people, kinda cutting it close. I've pulled a 5800 pound boat and it wasn't a fun trip. If you plan on pulling a trailer that big regularly I would look at a full size, or a smaller trailer.
  4. Sep 18, 2019 at 1:48 PM
    bchbm1966
    ok get a smaller trailer then? The guy with trailer supposed to call me back on weight he says he thinks the dry weight is 5000 so ya probably to dam big it was nice 2. They wanted 8900 for it and i found one in carson city same thing for 13000 so it was a good deal
    irayfz6 and Taco critter like this.
  5. Sep 18, 2019 at 1:53 PM
    JJ Customs
    Jay
    NV
    There are a lot of trailers on the market that are in the 3,500lb range and I would consider that optimal for your rig. Not sure what configuration you have but keep in mind the cross winds you might come up against. The short wheelbase of the Tacoma can cause them to get away from you quick if towing in a crosswind. It is not pulling the weight that is the issue it is stopping it and keeping it strait. Also make sure you get the correct hitch and sway bar setup, I see a lot of people towing to much weight without equalizer bars and that makes all the difference.
    My neighbor was towing a 40’ camper without equalizer bars with a trailer with two jet skis behind his trailer. I saw his rig sitting across from my house and I was like “hey bro, I would not throw my family in that and head out” and he had no idea they even existed despite the receiver and trailer being setup for it. Just went and bought a 1 ton Dodge with a Cummins and figured he was good.
  6. Sep 18, 2019 at 2:25 PM
    bchbm1966
    so when i get the right trailer do i go get this sway bar at an accessory place ? Sorry i dont know shit about towing a trailer but im willing to learn
  7. Sep 18, 2019 at 2:45 PM
    bchbm1966
    hey jj the guy thinks its 5000 dry weight what if i dont add gear and when i travel keep all the tanks empty. Id just b throwing in a duffle bag and a 5lb dog and ice chestpopout.jpg bathroom.jpg kitchen.jpg
    BillsSR5 likes this.
  8. Sep 18, 2019 at 2:48 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I wouldn’t go near that with a Tacoma, especially when towing at altitude and up hills in Colorado.
    JJ Customs, irayfz6 and bchbm1966[OP] like this.
  9. Sep 18, 2019 at 3:36 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    buckhuntin-tacoma likes this.
  10. Sep 18, 2019 at 3:39 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  11. Sep 18, 2019 at 3:42 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Look at keeping it around 4000 lbs dry and 24 ft max.
    4000 lbs dry gives you a good margin to load up with gear and people.
    The Tacoma wheelbase is too short for stability for anything longer than 24ft.
    JJ Customs and bchbm1966[OP] like this.
  12. Sep 18, 2019 at 3:45 PM
    bchbm1966
    thank u guys for the tips
  13. Sep 18, 2019 at 3:50 PM
    xrobwx71
    xrobwx71 Active Member
    Rob
    2019 Toyota Tacoma Midnight Black TRD Pro
    Welcome to TW!
  14. Sep 18, 2019 at 3:53 PM
    JJ Customs
    Jay
    NV
    Yeah, that is way larger than I would touch with a Tacoma. Sorry. The equalizer bars normally come with the trailer.
  15. Sep 18, 2019 at 3:55 PM
    bchbm1966
    ok thank u
  16. Sep 19, 2019 at 8:28 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Welcome!
  17. Sep 20, 2019 at 6:02 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  18. Sep 29, 2019 at 10:16 PM
    bchbm1966
    i found the perfect trailer 16 ft toy hauler. This should b just fine.
  19. Sep 29, 2019 at 10:34 PM
    JJ Customs
    Jay
    NV
    Make them take a little off for the non matching wheels.
  20. Sep 29, 2019 at 10:36 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Trade it for a tundra crewmax
