I made a mistake!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by A_Ninja_Racer, Jan 2, 2010.
  1. Jan 2, 2010 at 7:18 PM
    A_Ninja_Racer
    A_Ninja_Racer [OP] Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Ok Guys I was playing around the other night in my truck and was driving around and through this little pond when I accidentally found a pretty deep spot. The front end was pretty submerged but the intake and filter stayed above water and engine kept running smoothly the whole time. The issue I'm dealing with now is I thing the bearings in one of the idler pulleys or tensioners is starting to go bad. I recall reading about bearings in the pulley system going bad when they get submerged in water somewhere but could not find this in the search. is there a specific pulley that is known for going bad or could it be any one of them. Also My truck is still under warranty should I bring it in and let them fix it or will they be able to tell that it was under water and possibly void my warranty or something.
  2. Jan 2, 2010 at 7:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Im pretty sure they will be able to tell it was submerged, but they may replace it anyway.
  3. Jan 2, 2010 at 7:22 PM
    A_Ninja_Racer
    Tampa, FL
    do you recall what pully it is that goes bad?
  4. Jan 2, 2010 at 7:23 PM
    Brunes
    Brunes abides.
    Rotorhead
    Take it in and let them take a look at it- See what falls out. I don't think there is anything you can do but replace that pulley....so worst case is you go that way.
  5. Jan 2, 2010 at 7:25 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I have heard of this but have not experienced it I go through deep water crossing a good bit but I normally keep my speed up pretty good. Ill be subscribed to see what happens.
