I Made a Suction Phone Mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hondogarage, Nov 11, 2020.
  1. Nov 11, 2020 at 10:18 AM
    hondogarage
    hondogarage [OP] New Member
    2017 SR5
    We have been making Products specifically for the Tacoma, but we wanted to give the option of using our phone or tablet mounts in other areas.
    A suction mount was what we landed on for maximum flexibility. The Mother Sucker is a combo of the beefiest Suction cup we could find and a CNC machined housing with an AMPS pattern on the back.
    You place the suction cup on the surface you want to adhere to, then you pump the small piston on the side in and out to generate vacuum. Once it has been pumped a few times, the piston stays retracted. If for some reason the seal is not good and you start to loose suction, an orange indicator line shows up telling you to give it a few more pumps.
    Mother Sucker Suction Mount
    https://shop-hondogarage.com/collections/toyota-tacoma-mounting-systems/products/sucky-suction-mount
    dilbert likes this.
