I may already know the answer, but
Discussion in 'Technical Chat' started by bigburrito, Jul 16, 2010.
  1. Jul 16, 2010 at 1:41 PM
    bigburrito
    bigburrito [OP] Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    why cant I use my OBA tank as a sort of "temporary turbo"? Assuming the air in my tank is at 150 psi, and the average turbo runs what 10 psi maybe, why dont people just hook up a line to the intake and call it a day? Flip a switch when you want the compressed air bootleg turbo and get a nitrous-esque burst of power.
    Is it a flow rate thing? probably not enough air volume to make a difference is what my brain is telling me.
    :crapstorm:
  2. Jul 16, 2010 at 1:44 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    The air would run out in a few seconds and if but compresed air in the motor without adding more fuel it will be way to lean and burn up pistons. I just doesnt work.
  3. Jul 16, 2010 at 1:45 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    have fun putting 150psi into your engine...bye bye seals.
  4. Jul 16, 2010 at 1:48 PM
    bigburrito
    DuPage County
    '09 TRD OR
    i would use a regulator to dial down the psi equivalent to what a turbo would run. just crank it down to 10, 20 whatever would be correct. if there is such a thing as "correct" in this scenario.
  5. Jul 16, 2010 at 1:51 PM
    bigburrito
    DuPage County
    '09 TRD OR
    thats pretty much what i was thinking. the air would be gone in a matter of seconds. but, if thats all you needed, then it might work. maybe just use it for passing, or drag racing Raptors?
  6. Jul 16, 2010 at 6:32 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    No way would your OBA produce enough flow. It has the Psi but it has to produce a large amount of air flow at that pressure. You would need a very large valve with a very high flow regulator. Even with that it would last less than a second at the volumes of air it takes to produce the smallest amount of positive pressure in the intake.
  7. Jul 16, 2010 at 6:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo! CFM is the issue.
  8. Jul 16, 2010 at 6:55 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    a typical on board air system compressor pumps at about 2-3 cfm. and takes about 1-2 minutes to fill a 2gallon OBA tank. the V6 requires about 400CFM to run. To get any performance youd have to push 500CFM at 6-8lbs. your 2 gallon tank would last about .3 seconds...literally...
    plus the fact 1/2" hose can only carry about 10cfm at 8psi...
