I might have goofed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Will3.0, Oct 18, 2023.
  1. Oct 18, 2023 at 4:20 PM
    Will3.0
    Will3.0 [OP] New Member
    Southern Colorado in the hills.
    2011 Toyota Tacoma
    none
    I had less than a 1/4 of a tank of fuel in my 2011 Taco and put a 5 gallon can of gas in. I thought it might have had some water in the can as it ran rough and blew out white smoke for about 20 minutes. Sometimes it ran fine at 2-3k rpm's other times it was rough and coughed like it had a lot of back pressure. This can used to have diesel in it and I don't know if it was residue and water or a full 5 gallons of gas. Need advice from anyone who is more mechanically inclined thamn I am. Thank you in advance.
  2. Oct 18, 2023 at 4:34 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    How many miles did you drive it that? I would siphon it all out right away and put some fresh gas in it with a fuel system cleaner.
  3. Oct 18, 2023 at 4:45 PM
    Will3.0
    2011 Toyota Tacoma
    none
    Less than 5 miles and let run for 30 minutes.
  4. Oct 18, 2023 at 4:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Drain the tank. Don't be surprised if the pump is damaged
  5. Oct 18, 2023 at 4:50 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    yeah......i would drain the tank and start fresh. you might of damaged your injectors
  6. Oct 18, 2023 at 4:57 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    I would also add some seafoam in the gas and through the brake booster to help clean everything out. This will cause the exhaust to puff out a ton of white smoke, but it's normal with seafoam.
    If you're not sure how to do any of this, have it towed to a mechanic and have them professionally clean out the fuel system.
    jackn7 likes this.
  7. Oct 18, 2023 at 5:03 PM
    Will3.0
    2011 Toyota Tacoma
    none
    Thank you, that is beyond my mechanical capacities. I did add Seafoam.
    jackn7 likes this.
  8. Oct 18, 2023 at 5:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like you had diesel in that can instead of gas, drain the tank, put fresh gas in it, and I bet it will be fine.
    TnShooter and GilbertOz like this.
  9. Oct 18, 2023 at 9:57 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Blew out white smoke or white steam?
