I need a leveling/lift kit installed in Austin Tx, anyone??
Discussion in 'Texas' started by Atxtoolz, Jan 6, 2011.
  1. Jan 6, 2011 at 9:05 PM
    Atxtoolz
    Atxtoolz [OP] Well-Known Member
    05 PreRunner
    Hello guys looking to install one of these kits I live in Austin
    I believe its a 3" front and 2" rear plus leveling and Ive heard its like a 2 hour install.
  2. Jan 6, 2011 at 9:08 PM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    2014 Ford Raptor
    Krawltex Motorsports in Cedar Park.
  3. Jan 7, 2011 at 5:36 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Cedar Park / Austin
    2013 DCSB MGM TRD OR 4x4
    Fox 2.5 c/o, Camburg UCA, OME Dakar, Fox 2.0 rear, LED interior light kit, LED fogs, LED headlights, Nitto G2, MB black wheels, diff breather mod, All AMSOIL syn fluids, XRXS bed cross bars, full debagged, shortened OEM antenna mod, Wet suit seatcovers, and fog light any time mod.
    X2 for Krawltex. However front spacers and rear blocks not my first recommendation for a small lift. I would go with Bilstein 5100's all the way around with a rear add a leaf just my 2 cents. Read up on front spacers here on TW before you get it installed.
  4. Jan 7, 2011 at 5:38 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
     yes what he said x 120000
  5. Jan 8, 2011 at 4:19 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    What they said^^^^^
  6. Jan 8, 2011 at 4:35 PM
    Rhody76
    Rhody76 Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    If you go with the Bilsteins all around and the add a leaf in the rear are additional upgrades necessary as well? There is a lot of talk about after market UCAs, diff drops, etc. Why or why not would these components be added as well?
    I have also have read several threads where people with the Bilsteins all around and AAL in rear have complained about very stiff ride and issues with vibrations, floating on highway, etc
    Just trying to get all this straight as there are many arguments for and against both kinds of lifts and I am trying to figure out which to go with too. Thanks
  7. Jan 8, 2011 at 4:43 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
  8. Jan 8, 2011 at 4:43 PM
    BenJammn5
    BenJammn5 RN
    San Francisco
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Kind of a mouth full to explain every detail, but you really gotta do your research when upgrading your truck. I'm not suggesting that you haven't researched or looked into suspension on our trucks, but spacers will likely destroy your current bilsteins if you ever take your truck in the dirt and drive it hard.
    While top place spacers do not put any load on the spring (compress the spring to lift the truck) they do push the entire coilover further down, which means the shock is further away from the bump stop that prevents ultimate destruction. As a result, the shock is turned into a bump stop... and this is what happens. Read camburgs explanation here and see why http://www.camburg.com/toyota/07-09-tundra/read-before-you-buy-a-spacer-lift/
    Bare in mind that if you do not off road your truck at all, or take hard speed bumps (ridiculous) then spacers will be fine for you.
  9. Jan 8, 2011 at 4:49 PM
    BenJammn5
    BenJammn5 RN
    San Francisco
    Tacoma world is the real world, if the crowd says they break components, they're probably right, and while ready lift and the rest of the company's that produce spacers say good things about them, keep in mind it's a business. If the people are buying junk then why stop selling the junk? Kinda like cigarettes.
  10. Jan 8, 2011 at 11:03 PM
    Atxtoolz
    05 PreRunner
    I'm going to do my research before I install anything sounds kinda complicated now
  11. Jan 8, 2011 at 11:06 PM
    jeeezy
    jeeezy jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    i have a ready lift on my truck no probs with it
  12. Jan 8, 2011 at 11:09 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    When i had my spacers on i did it myself, and did an AAL. I imagine that the blocks and the spacers would be just as easy, it took me awhile because it was my first time under the truck. But held up great
  13. Jan 9, 2011 at 10:02 AM
    06HAOLE
    Sherman Oaks, CA
    2014 Ford Raptor
    I think you will want to take that off in a few months. I helped my buddy do that on a Tundra and 2 months later we put in 5100s up front and a full leaf pack in the rear. If I were you I would take that back and save for a better lift.
    EDIT: Basically I wouldnt mind helping you do the lift but I dont like doing things twice. Trust me I have done this a few times.
  14. Jan 9, 2011 at 10:10 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Never done a lift, but would be interested in helping in you out if that is what you're looking for. Wanting to learn, but no experience, and I live in Fort Worth; doesn't sound like much help, but I'm in. I might even be interested in flying down if you went the Bilstein route.
  15. Jan 9, 2011 at 2:14 PM
    tacopromatt
    tacopromatt Matt's Pro Taco
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    If you're in South Austin, Jeep Masters is not a bad alternative. They did a great job on my cab mount shop and aligning after my UCA's.
  16. Jan 9, 2011 at 4:28 PM
    BenJammn5
    BenJammn5 RN
    San Francisco
    thats because owning a tacoma is just a way of life
