i need a lug nut key!
Discussion in 'Wheels & Tires' started by derekAV, Apr 23, 2010.
  1. Apr 23, 2010 at 12:33 PM
    derekAV
    derekAV [OP] Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    i lost my key for the locking lug nut deal..if anyone has a spare one id gladly take it off your hands!
    went to the dealership and they wanted $25 for one!
    thanks guys
  2. Apr 23, 2010 at 12:57 PM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
  3. Sep 12, 2012 at 11:51 AM
    undersc0re
    undersc0re Well-Known Member
    BC Canada
    exhaust and k@n filter setup.
    I bought a used 2008 tacoma and can not seem to find the lug nut key. Is there a special place this is kept or do I have to get one new from somewhere? Stock rims...
  4. Sep 12, 2012 at 1:33 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    07 sport, ARB rear locker, leveling kit
    ARB rear locker Leveling Kit Custom Rear Bumper Tires and Rims Air tank fully plumbed into truck
    Go to Wal-Mart, pick up "gator grip socket" it's a universal socket for any nut or bolt. Lightly grind off the round portions of the pins in the socket so that you are left with a nice flat edge on the pins. The press it over your keyed lug nut and turn. It should grab enough to undo your lug nuts if they are not over torqued
  5. Sep 12, 2012 at 1:40 PM
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights, aFe CAI, Borla Cat-back exhaust, Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts.... It has more stuff done to it now.
    Go to Les Schwab, they normally have all the most popular ones and you can buy them form them.
  6. Nov 13, 2012 at 9:14 AM
    undersc0re
    BC Canada
    Went to the local big tire shop, charged me 60 bux to remove all 4, and 15.50 for new regular toyota replacement factory lugnuts. Got the tires balanced and an alignment done while it was there just to make me feel better as the truck was just bought used a couple months ago! All was well except 2 tires were quite a bit out of balance causing the shake I was experiencing! They just gave me a print out of the alignment and said they were not going to charge me for an alignment because it was good. Very good experience for me! I thought it was gonna be real expensive to fix the lugnut issue....
