I need a new exhaust
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNH, Feb 23, 2023.
  1. Feb 23, 2023 at 8:13 AM
    TacoNH
    TacoNH [OP] Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    My exhaust now has 4 patched rust holes and last week a hanger ripped free and left an enormous hole that cannot be fixed. It's time to replace it and wanted y'alls opinion on which direction to take. OEM is crazy expensive so I'm looking at aftermarket but my biggest concern is noise level. My Tundra has dual flowmasters, it's obnoxious but sounds good IMO. I am looking for a good exhaust with a good tone but overall not super loud. What do you recommend? Would love links too!
  2. Feb 23, 2023 at 8:21 AM
    Waasheem
    Waasheem
    2007 xrunner
    Maybe you’ll get lucky and find someone with a stock take off they’ll trade for a ham sandwich.
  3. Feb 23, 2023 at 9:57 AM
    TacoNH
    Nü Hampshire
    LOL I wish, I am in the middle of nowhere in NH and I need something ASAP.
  4. Feb 23, 2023 at 10:07 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Wicked Flows WF-SS212. If you have cats, you shouldn't need a resonator. Any reputable muffler shop should be able to bend and weld it up for you. Not sure what the going rates are in your neck of the woods, but I wouldn't think it would be more than 100$ installed.
    -J
  5. Feb 23, 2023 at 10:55 AM
    TacoNH
    Nü Hampshire
    We certainly don't have a muffler shop or even a fab shop but I have my own garage to install it myself if it's a bolt on application.
  6. Feb 23, 2023 at 4:20 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    We had a good muffler shop in Nashville, Illinois. I had him do some work from time to time and he did a great job and was reasonable. I even had him weld on my sliders and he did a fantastic job.
    I know that doesn't help you but if you didn't live in BFE....
  7. Feb 23, 2023 at 5:28 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    A budget alternative to OEM is Walker Quiet-Flow SS exhaust. It says it's stainless steel, but it's low grade. But it sounds quiet, OEM like, and does the job.
    winkel and muddog321 like this.
  8. Feb 24, 2023 at 2:09 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Second the Walker Quiet Flow (with attached tail pipe segment) and can get at the big auto stores and they have the mid-pipe too all fits right in. Both about $150.
    You will need a new kit for the mid pipe to cats spring/bolts with a donut gasket. I sprayed the entire system with black Rustoleum high heat so has held up for last 3 years so far but lifetime warranty.
    Several other brands are similar if Walker out of stock.
  9. Feb 24, 2023 at 4:20 AM
    theOnlyElChapo
    theOnlyElChapo Member
    Ontario, Canada
    I bought my truck in October of last year from one of the best rated local dealerships. One of the things they needed to replace was the muffler. They were unable to source an OEM muffler so outfitted me with a walker muffler instead. Looks and sounds fine, seems like a quality product to me.
  10. Feb 24, 2023 at 8:08 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    Walker is OEM Muffler on lots of vehicles. know when i was with Honda back in the day Walker and Sanki were stamped into every muffler somewhere. think Subaru is also Walker, as for the tacoma ive no idea never pulled my exhaust off.
  11. Feb 24, 2023 at 1:54 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Walker products don't last long in the rust belt. At least the stuff from the parts stores
  12. Feb 24, 2023 at 2:15 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    parts store stuff is likely aluminized which is a bandaid in rust belt
  13. Feb 24, 2023 at 4:38 PM
    winkel
    Corydon, IN
    You poor rust belt bastards......
    I really feel for you.
  14. Feb 25, 2023 at 4:58 AM
    fixnfly
    S.W.PA
    On a positive note, we don't have earthquakes, hurricanes, wildfires....
    :thumbsup:
  15. Feb 26, 2023 at 12:36 PM
    winkel
    Corydon, IN
    True. When we lived in southern Illinois, we SAW five tornados in the 11 years we lived there. One actually did some damage to our house. I'll still take salt free (for the most part) roads!
  16. Feb 27, 2023 at 8:58 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    worked with a tech who was from CT, i remember the first time he saw a pre 2000 subaru come in i saw him digging out so much stuff to work on the car like an induction tool for bolts, and breaker bars and soon as he saw no salt he said this is why there are so many old cars here.. cracked me up
  17. Feb 28, 2023 at 9:13 AM
    TacoNH
    Nü Hampshire
    It's incredible, when I was in highschool I was in the auto-tech program, half of the time was spent with breaker bars and gallons of PB Blaster fluid. My poor 2007 is starting to rust in the cab corners too.
