I need a new window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VolNut, Oct 4, 2011.
  1. Oct 4, 2011 at 3:19 PM
    VolNut
    VolNut [OP] Well-Known Member
    Rick
    TN
    So there I was on a fine fall afternoon, got off of work early and decided to mow the grass. Everything is going smoothly until my weedeater decides to transform itself into a rock launcher.
    You guessed it. Took out the passenger side front window. It's in a million pieces but still in place.
    The question is should I go to an auto glass place or the dealer? Also, any ballpark prices on how much this is gonna set me back.
    Appreciate it fellas.
  2. Oct 4, 2011 at 3:37 PM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    what year truck and what cab? its easy to put a door glass in
  3. Oct 4, 2011 at 3:44 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Id say an auto glass place would be cheaper. Google some stuff and look for some prices to compare.
  4. Oct 4, 2011 at 3:50 PM
    VolNut
    Rick
    TN
    Oops... 09 double cab.
    How hard is it to do myself?
  5. Oct 4, 2011 at 3:50 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Don't go to dealer. Friend has a 08 sequoia. And they quoted 600 just to replace it!!!! Eff that.
  6. Oct 4, 2011 at 3:54 PM
    VolNut
    Rick
    TN
    Gold plated window? Thats nuts!
  7. Oct 5, 2011 at 1:41 AM
    slo13zx3
    Brian
    forest city pa
    you will need a set of sockets take door apart clean out the glass ''shopvac'' the door and run a tool where glass is stuck in the top and sides of the strip and drop door glass in
  8. Oct 5, 2011 at 1:45 AM
    Gluis123
    Gluis123 Active Member
    Luis
    Hemet, California
    '02 2WD 2.4 Tacoma
    I believe it is just two bolts to take it off
  9. Oct 5, 2011 at 1:52 AM
    Gluis123
    Luis
    Hemet, California
    '02 2WD 2.4 Tacoma
    Here I know you have a 2nd Gen but the process is similar
