I Need a Person Who Knows Audio - Family Interviews
Discussion in 'Off-Topic Discussion' started by e_engstro, Jul 25, 2025 at 4:05 PM.
  1. Jul 25, 2025 at 4:05 PM
    e_engstro
    e_engstro [OP] Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    Hey folks,
    I need some who knows audio and recording better than I do for something that is probably not very complicated to begin with.
    What I am planning on doing is interviewing family members to gain a better understanding of family history. I want to record the interviews and have them to get the family history but to also have something to be able to pass down to future family generations. Sure, I can ask and have conversations on this stuff but I want to record it for the record so future family members can hear voices as I feel this is important when family members pass.
    I bought a Zoom H1 essential (cool little device) with a 2 lavalier mics. I recorded a quick conversation with my wife for shits and giggles. When I went to edit, I realized that the Zoom H1 isn't a multi-track recorder and all the mics got recorded as one recording basically and I wasn't able to edit each separate mic.
    So my question is what should I get/how should I do this? For the interviews, there won't be probably more than a total of 3 people in each one. I don't necessarily want to get something that is too much for what I need either but I want to make sure I have enough for say a total of 3 people (including myself as the interviewer). I don't plan on filming the interviews with a camera, just recording the audio.
    Thank you!
  2. Jul 25, 2025 at 4:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Right on and good luck!
    e_engstro[OP] likes this.
  3. Jul 25, 2025 at 4:25 PM
    bassmusic
    bassmusic Coastal Redwood Cultivator
    Spicoli aka ChrisTOEpher
    Chapel Hill NC
    19 Tacoma SR5
    According to Google AI:
    To record a conversation with separate audio tracks for each participant, you'll need software or a hardware device that supports multi-track recording. Software like Audacity, Logic Pro, or specialized tools like Rode Connect (for Rode microphones) or Audio Hijack, allow you to record each microphone input or audio source as a separate track. Hardware options like the Sound Devices MixPre-3 or Rodecaster Duo also offer this capability.
    e_engstro[OP] and Steves104x4 like this.
  4. Jul 26, 2025 at 8:14 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    e_engstro[OP] and bassmusic like this.
  5. Jul 26, 2025 at 11:38 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i don't know of a solution off-hand without a ton of research, as my experience is in car audio, and comprehensively breaking a church audio system. around covid, i ran really deep into the black magic lineup to set up church live video feeds, but again, most of the solutions are nearly all 2-channel stuff.
    rode might be the cheapest 'private' option. i know of their mic's, and they've had some of the best-bang-for-the-buck features for quite some time.
    the problem with what you want to do is that it's on the immediate fringe of professional recording-- the kind where there's a very expensive trained guy sitting behind very expensive equipment, doing his thing while everyone focuses on their talk.
    overall, it's going to be difficult to have a solution that records separate audio tracks without delving into some pro gear.
    rode's got a few private label solutions, which can be good or bad. i don't know their software, and private label editing tools can be really hit or miss.
    if you're tech savy enough, OBS should also do it--it'll depend on the computers input card setup. being an open source program, it tends to do everything like a leatherman. but also like a leatherman, it'll never replace real professional solutions. OBS is like linux. to set it up right, it either all magically works with no explanation, or needs DAYS to kinda work like that one youtube video that makes it look easy.
    https://www.youtube.com/watch?v=HWVZ07qP2g0&t=1s
    and i don't know your overall setup during the talks, but of long term audio quality is your focus, the ubiquitous 'gamer mics' like this will have much better audio quality than the lav mics.
    https://www.amazon.com/Amazon-Basics-Microphone-Podcasting-Adjustable/dp/B0CL9BTQRF
    i've always struggled in the church setting using lav mics-- either they're high up on the shirt, and the listener is 'hearing' the talkers chin, or they're further down, but then too far from the mouth, so pickup becomes extremely sporadic.
    church migrated to using a higher-end version of these instead
    https://www.amazon.com/XGWTH-Microphone-Omnidirectional-Compatible-Transmitter/dp/B09FZ2285C
    most speakers found usage to be far more natural, and as the sound person, i found they were far more consistent in getting good quality audio.
    if you're in a sitting/table setting, one could be using a professional mic like this
    https://www.amazon.com/Condenser-Microphone-MAONO-Professional-Home-Studio/dp/B088FH47ZS
    and then, you could use a 'podcast recorder' like this, which records each input as a separate track, to be saved/mixed into the final recording later on.
    once you get a unit like the zoom, it takes normal XLR inputs, which means that all your audio input options are now of the professional grade variety. XLR is a well-documented pro-grade standard, so mixing-and-matching components to get the right input setup gets a lot easier after that.
    if you needed either of those above over-ear mics, or table mics to be wireless from the recording unit, you'd need 3 of these
    https://www.amazon.com/Kadjuh-Wireless-Transmitter-Rechargeable-Microphone/dp/B0CGTJS4XV
    to get the over-ear mic into the wireless adapter, you'd need a mini-xlr-to-xlr adapter
    https://www.amazon.com/Female-Adapter-Cable-Camera-Assist/dp/B07ZVXGDS7
    like i said, audio gear has a tendency to run away on price. it all depends on your requirements. the closer to 'talking at a table' the setup can be, the cheaper the setup will cost to build.
    the disadvantage here is that every interview you do will require post processing that's going to take at least 1.5-3 times the length of the interview to post-process the audio and create the final product. it's a massive time commitment, far beyond just talking to people.
    as much as you or i might not like it, the 'podcast recorder' is likely going to be a big producer keyword in your search. when i set up the live stream at church, as much as i hate youtube influencers, searching their setups and any parts geared towards that genre revealed the most cost-effective options for price ranges that didn't have a california budget.
  6. Jul 27, 2025 at 9:00 AM
    e_engstro
    Eric
    Arizona
    Thank you for your time writing all of this up, I appreciate it! What recorder were you referring to for the link that you sent? It appears you copied a microphone link.
    Steves104x4 likes this.
  7. Jul 27, 2025 at 9:38 AM
    soundman98
    NW Indiana
  8. Jul 27, 2025 at 9:53 AM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    If you want multitrack recording, I'm pretty sure you'd need separate mics and an interface with multiple inputs to split that audio. USB mics might get you by but I'm not sure how your computer would deal with more than one plugged in and recording at once. You'd also need a DAW (Digital audio workstation) to record the audio into. Reaper is what I use for demo purposes (it's not free...but the trial period is indefinite so...), as far as mics I'd do a couple from audio technica, they have really good bang for buck condenser mics, and an interface from focusrite used won't break the bank either. From there it's just XLR cables from the mic to the interface and setting up the number of tracks you want to record. My quick cursory check pulled this up, which is pretty good! You'd just need a second mic is all
    https://www.sweetwater.com/store/de...ErVhFgXg5f3P04PtOmxVf0TOHQ-g0WCMaAv9MEALw_wcB
    And
    https://www.adorama.com/us1958579.h...ZTOBWUSw9H47jPJz1IKOYPsDYcaiNN4oaAhaSEALw_wcB
