I Need A Rifle Scope for Under $100
Discussion in 'Guns & Hunting' started by hillbillynwv, Sep 15, 2011.
  1. Sep 15, 2011 at 5:40 AM
    hillbillynwv
    hillbillynwv [OP] Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I recently purchased a Savage-Stevens Model 200 .270 bolt action rifle from a friend. The gun had cheap scope bases,rings, and a Chinese scope on it. I told him to keep the scope, rings, and bases and I would buy new.
    I'm going to buy new standard Leupold bases and medium rings. I want a 3-9x40 scope for this gun. With the holidays around the corner I can't be spending a lot of cash right now. So, what is the best bang for my buck for a under $100 3-9x40 scope???? This gun will be used for whitetail hunting. Next year I will look for a better than $100 scope when I can afford it.
  2. Sep 15, 2011 at 5:48 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I was allways told to spend the same amount on a scope as you do on the rifle.
    You may find a used quality optic for a hundee but if you can hold out to spend more for higher quality unit later it may be worth the wait.
  3. Sep 15, 2011 at 6:13 AM
    Vandy
    Vandy Well-Known Member
    Jake
    Pasadena, MD
    2008 DC-LB, 4x4 SR5, Indigo Ink
    Redline Hood Struts, Blacked out Badges, Blacked out SR5 Wheels, BFG All-Terrains, aFe Pro Dry Air Filter, Wicked Flow Muffler
    I've bought my fair share of "cheap" scopes when I was younger. Most failed after a couple years and were never as bright as the better scopes on my guns. I've used scopes ranging from $60 up to $1,000 for a precision rifle.
    My recommendation is to bump your budget to at least the $150-$200 range. I recently purchased a Redfield 3-9x40 at Bass Pro for $160. I haven't had the opportunity to use it in low light in the woods yet, but based on my initial impressions, I would rate it between a Leupold V-X1 and V-X2. In my opinion, it is better than the Nikon ProStaff series (which is my favorite "cheap" scope and approaches the Buckmaster series.
    The Redfields are made in the U.S. by Leupold and have their same warranty. I picked mine up for $160 and, for a variable power, have not used anything in that price range that I would say is better.
    Good luck.
  4. Sep 15, 2011 at 6:15 AM
    98tacoma27
    Ben
    Not Beech Creek
  5. Sep 15, 2011 at 6:51 AM
    hillbillynwv
    Fairmont, WV
    I agree with what everyone is saying here, you get what you pay for. I was just checking out the new Redfield Revolution scope. My 35 year old Marlin 30-30 that I'm retiring has a 4x Redfield Widefield scope that has never failed me. So, I am a Redfield fan. I'm glad a company like Leupold is making them now and not some Chinese factory.
  6. Sep 15, 2011 at 6:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Always been a Redfield fan myself.
  7. Sep 15, 2011 at 7:46 AM
    Vandy
    Jake
    Pasadena, MD
    I really do like the new Redfields and will likely purchase another. They compare to Leupold's in their physical size and have a fairly small overall diameter on the eyepiece which I really like. It feels solid and has a good finish. You can adjust the windage and elevation with your fingers and don't need a coin or other tool which is definitely a plus. They also seems to have a slightly longer eye relief than other comparable scopes. I ran mine through the box test before zeroing. Since dialing it in I've run about 40 rounds of 20 gauge slugs through it in my H&R Ultra Slug and the zero is holding true so far. While I haven't tested it in the field in low-light or rainy weather, so far I haven't found anything I dislike about it for the money.
  8. Sep 15, 2011 at 8:42 AM
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    I bought a Redfield last November - great scope, keeps zero and is built tough. Redfield is the budget line from Leupold if anyone's ever read the manual to theirs.
  9. Sep 15, 2011 at 1:48 PM
    28ØØ3
    28ØØ3 Well-Known Member
    boss
    somewhere endlessly searching for ways to offend B
    08 DCLB SR5 4WD
    VatoZone Especial
    these guys have a great rep for products and great customer service: http://www.primaryarms.com/product.sc?productId=1063&categoryId=156
  10. Sep 15, 2011 at 6:33 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    i have a Tasco Golden Antler from my 1200 FPS air rifle. when i upgraded to real guns i tried it on my AR-15. it has been holding at 0 for a little over a year now. it's been accurate with 1/2" - 3/4" groups at 100 yards. i'm going to use it until it breaks and by then i will have saved up enough money to buy some real glass.
    tasco golden antler
    try Tasco brand, they all seem to be under $150
  11. Sep 15, 2011 at 6:37 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
  12. Sep 15, 2011 at 6:40 PM
    Sullyman
    Sullyman Crusty ole' conservative fart
    Augusta, Georgia area
    2010 Black TRD Sport
    Cat-back exhaust, BluLogic, Back-up Camera, Extang Solid Fold Tonnau cover, Pop-n-Lock PL8521 electronic tailgate lock, Illuminated 4x4 switch, Smittybuilt Nerf Step Bars, Toyota bed mat, Tinted the windows darker, CB with custom fab'd antenna mount, Grillcraft grill, AFE Pro Dry S filter with secondary filter removed. Differential breather relocation mod. Bridgestone Dueler AT/Revo 3 tires Weathertech mats Spec-D HID Halo's Bilstein 5100s front set at 2.5" w/OEM springs 4-leaf TSB w/ SkyJacker add-a-leaf 2" block lift 1.5" wheel spacers Freedom Off-Road upper control arms .5" coil spacers ATOTO A6 Android double-din head unit
    Make sure you spend at least enought to get one that's nitrogen purged to make if fog-proof....
