I need a wheel & tire expert
Discussion in 'Wheels & Tires' started by 2011Tacoma1293, Oct 17, 2011.
  1. Oct 17, 2011 at 10:21 AM
    2011Tacoma1293
    2011Tacoma1293 [OP] Well-Known Member
    Kevin
    Florida
    11 Tacoma 4cyl Barcelona red
  2. Oct 17, 2011 at 10:28 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    tires arnt gonna cause you any problems. and you should be okay with those rims
  3. Oct 17, 2011 at 10:38 AM
    2011Tacoma1293
    Kevin
    Florida
    Thanks alot tire expert haha:thumbsup::thumbsup::thumbsup:
  4. Oct 17, 2011 at 10:55 AM
    2011Tacoma1293
    Kevin
    Florida
    how much more would the tire stick out of the fender? or compared to the stock steelies?
  5. Oct 17, 2011 at 11:03 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I would check the tire manufacturers website to make sure that their 265/70/17's are approved for 9" wide rims.
    Those will stick out 2.75" more than stock.
  6. Oct 17, 2011 at 11:14 AM
    2011Tacoma1293
    Kevin
    Florida
    :cool:
    it says up to 8.5" its a good year duratrac. any chances?
  7. Oct 17, 2011 at 11:25 AM
    TexasTacoma37
    Any chances of what? :confused:
  8. Oct 17, 2011 at 11:28 AM
    2011Tacoma1293
    Kevin
    Florida
    of fitting them on the 9" wide wheel?
  9. Oct 17, 2011 at 11:29 AM
    2011Tacoma1293
    Kevin
    Florida
    good year says the duratracts fit up to a 8.5" wheel will the 9" wide wheel work?
  10. Oct 17, 2011 at 11:33 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    I wouldn't chance it. 8.5" is the max for a reason. If it was good for up to 9", it would say so.
    Use common sense man...
  11. Oct 17, 2011 at 11:35 AM
    2011Tacoma1293
    Kevin
    Florida
    Do you know any tires 265/70/17 that fit a 9" wide wheel?
  12. Oct 17, 2011 at 11:37 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Done.
    Fink
  13. Oct 17, 2011 at 11:41 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    No. I don't run that size tire.
  14. Oct 17, 2011 at 11:43 AM
    Fink
    Orlando, FL
    It's the size of the tire, not the specific tire, that will prevent you from being able to safely mount them on 9" wide wheels.
    Fink
  15. Oct 17, 2011 at 11:44 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You will have no issue running a 265 Duratrac on a 9" wheel. I know everyone here is saying don't do it because Goodyear doesn't "approve" it, but trust me, I can tell you from years of tire industry experience that you'd be fine. The worst you would have to worry about is wheel rash if you curb them or scrape them on rocks, because your sidewalls will be slightly stretched.
  16. Oct 17, 2011 at 11:44 AM
    2011Tacoma1293
    Kevin
    Florida
    what do you mean?
  17. Oct 17, 2011 at 11:47 AM
    2011Tacoma1293
    Kevin
    Florida
    Thanks a lot. Ill keep that in mind. Do you know of anyone running that tire with a 9" wheel?
  18. Oct 17, 2011 at 11:47 AM
    Fink
    Orlando, FL
    The manufacturer of the tire is not going to recommend it because the tires are simply not wide enough to "safely" seat on that wide of a rim.
    Fink
  19. Oct 17, 2011 at 11:51 AM
    2011Tacoma1293
    Kevin
    Florida
    i was trying to stay with 265 because i have a 4 banger and i dont want to get killed on mpgs
  20. Oct 17, 2011 at 11:56 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    Get a different wheel.
