I need help ASAP
Discussion in 'Lighting' started by SR5tacoma, Apr 7, 2012.
  1. Apr 7, 2012 at 12:24 PM
    SR5tacoma
    SR5tacoma [OP] Well-Known Member
    so i just installed some aftermarket fogs and i wired them into the driving lights(the little orange bulb in the corner on the lights) and all was fine turned on the lights worked like a charm turnd off the lights put the grille back together and tried them one more time and nothing...the driving lights dont come on at all not when i have the hi/low beams on not when i put just the driving lights on and the fogs don't work now either. what could have gone wrong in that 10 minute window....
  2. Apr 7, 2012 at 12:27 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Sounds like you blew a fuse.
  3. Apr 7, 2012 at 12:28 PM
    SR5tacoma
    fuck me that's what i thought it might be. where do i get a new fuse at? how much is that going to run me?
  4. Apr 7, 2012 at 12:37 PM
    mjm540ii
    Oxford, PA
    Not a diet coke, but a Sprite, maybe.
    1st gen or 2nd gen?
    A new fuse probably won't solve the problem. Do not buy a higher amperage fuse either to replace it. Get an "add-a-fuse" instead. Chances are, you still have a spare fuse in the fusebox somewhere. Check the fuses under the coin tray. The 3rd fuse on the top ("TAIL", 10A) should be the culprit if you did indeed wire the aux lights to the parking lights, like you said you did. This fuse also regulates your taillights. Turn your lights on and if they dont work, thats it. (Taillights, not brakelights)
  5. Apr 7, 2012 at 12:42 PM
    SR5tacoma
    2nd gen. 2011.
    ok i'll take look and se if that will fix the problem
  6. Apr 7, 2012 at 12:50 PM
    SR5tacoma
    yup tails are out. where is the extra fuse at?
  7. Apr 7, 2012 at 1:53 PM
    mjm540ii
    Oxford, PA
    THey should be located in the fuse panel under the hood. If not, youll have to go to the parts store and get a 10amp mini fuse
  8. Apr 7, 2012 at 2:28 PM
    SR5tacoma
    got it thanks man i really appriciate it
