I NEED HELP BAD, High RPM miss
Discussion in '1st Gen. Tacomas (1995-2004)' started by ob3135, Mar 12, 2013.
  1. Mar 12, 2013 at 1:33 AM
    ob3135
    ob3135 [OP] Member
    Alaska
    2002 Tacomma Pre-runner V6 Automatic
    None
    So hi guys. (I know this is a long post, but for you gear heads it's a nice challenge, that said I appreciate you reading all this, I am so depressed and stressed out of my Mind over this!)
    I'm still chasing this miss. I have gotten real serious now because for months it had been very distinctive and drive-able. distinctive meaning it was running absolutely perfect under 3200 RPMs so it hadnt been a issue that kept me from using the truck. I have been working on it and I took apart the Manifold to test the knock sensors, took the coils off and tested them as well as wires and plugs replaced the plugs. Put it all back together and now it runs like absolute crap at all rpms including idle.
    So, here is a description of problem, codes from OBD2 scanner, list of things I've done as well as live data freeze frames thru the RPM range until it hits the hard miss... PLEASE HELP :annoyed::annoyed::annoyed::annoyed:
    2002 3.4l tacoma
    Symptoms: High rpm miss at excact RPM 90% of time but would move around some as I manipulated parts, but always ended up back at 3200.
    Ocassionally would move into the 2400 rpm bracket, but like said went back to 3200.
    Sudden change after mecanical work to now running terrible and throwing missfire codes for cylinders 1,2,4,5,6... (Why not 3?) Also code for "Random Multiple Missfire"
    I have done the following.
    Checked spark (inline spark tester) (OK)
    Checked coils resistance they were in bottom of range but met spec just barely
    Checked fuel pressure (OK)
    replaced MAF sensor
    Replaced Igniter (Ignition Control Module)
    OHMS test Crank Position Sensor
    Ohms Test camshaft position sensor
    Put at TDC and verified cam pulley tabs lined up with notch in rear cam pulley cover
    (Timing marks on belt saying "Right Cam - Left Cam" did not line up with paint marks when at TDC, that said does that really matter as long as the tabs on the pulleys lined up with the notches as spec? the belt was replaced once way back ago buy a mechanic)
    Pulled lower intake and tested Knock sensors (did find bad wiring at plugs but still tested "OK" then fixed that and then re-tested buy checking base voltage then banging on them and watching voltage spike, confirmed "OK"
    Cleaned and tested fuel injectors all were actuated manually and confirmed even spray.. (Did notice two injectors wet at base after re-assembly, figured bad upper o-ring went bad from being messed with, so will have to fix that)
    checked fuel pressure at fuel rail and it is at 44 PSI per spec. Was not able to test pressure at the high RPM miss cause I tested this after it started running crappy.
    (But would a bad fuel pump cause a high RPM miss? Is that possible, I would think it would miss in all ranges with fuel pump going bad?)
    Ohms tested TPS sensor and it tested good but replaced anyway cause I suspected it. The live data shows with engine off ignition on the WOT reading is at 75%... Should the TPS be showing 100% at WOT? Maybe needs adjustment?
    Inspected all vacuum hoses, do not have a vacuum test gauge kit, it's on it's way from Amazon. Once again I dont think this is it, it seems to have good vacuum, you pull a hose from intake and it kills it, put it back on it runs.
    Checked all grounds
    Checked alternator
    changed fuel filter
    tested injector plugs and harness
    Did compression test. The test conditions were no throttle, just crank of engine period and read compression, all within 5% of each other. No leak down tester yet. It's in mail to me (I'm in Alaska) so for now have to wait for that, I know I probably should have checked compression at WOT right? but it met specs.
    So, at this point I dont know where to go next. I'm really lost here. It was in the Dealer for 5 weeks and they couldnt figure it out. Then in the end in week 5 they said they think the water pump leaked on timing belt and cause it to jump a caug/tooth but weren't positive. I took the truck back because I was of the impression that if the belt had jumped time it would run like crap all the time, then I removed covers and put at TDC and saw that even though the belt lines didn't line up the cam pulley tabs did line up and I'm assuming the last mechanic just put the belt on without lining up the marks on the belt. But what difference would that make? All that said, the water pump is most def leaking. It's obvious and has been a good long while.
    I dont know guy's I'm so lost and depressed, I swear. I'm thinking I'll re set timing just cause I dont know what else to do even though I think it's right. Also, I've heard if you dont torque that crank pulley bolt to proper torque (Like 250 ft/lbs) it can work loose and cause the crank sprocket to wobble and send incorrect info to the ECM from the CPS and cause a high RPM miss and then as it gets worse become a problem continuios not just at high RPM, possible it was that and when I was cranking it to TDC manually I loosened it up some more so it's now running like crap? Hell I dont know I'm grasping here.
    Here is the Code info and Live date. See the Frames per RPM ranges...
    2002 Toyota Tacoma 3.4
    I/M Monitors
    Since DTCs Cleared
    Misfire Monitor ok
    Fuel System Mon ok
    Comp Component ok
    Catalyst Mon inc
    Htd Catalyst n/a
    Evap System Mon inc
    Sec Air System n/a
    A/C Refrig Mon n/a
    EGR/VVT Sys Mon n/a
    DTCs (Codes)
    P0300 ENG $10
    Random - Multiple Misfire Detected
    HISTORY
    P0301 ENG $10
    Cylinder 1 Misfire Detected
    HISTORY
    P0302 ENG $10
    Cylinder 2 Misfire Detected
    H
    P0304 ENG $10
    Cylinder 4 Misfire Detected
    HISTORY
    P0305 ENG $10
    Cylinder 5 Misfire Detected
    HISTORY
    P0306 ENG $10
    Cylinder 6 Misfire Detected
    HISTORY
    Record Data @ IDLE
    FRAME: -1 TM: -3.4
    MIL STATUS On
    ABSLT TPS(%) 9.4
    ENG SPEED(RPM) 910
    CALC LOAD(%) 23.5
    MAF(LB/M) 1.02
    COOLANT(°F) 158
    IAT(°F) 61
    IGN ADV(°) 13.0
    ST FTRM1(%) 0.0
    LT FTRM1(%) 0.0
    VEH SPEED(MPH) 0
    FUEL SYS 1 OPEN2
    FUEL SYS 2 N/A
    EQ RATIO11 1.000
    OBD2 STAT CA
    @ light acceleration in neutral
    FRAME: 5 TM: 16.0
    MIL STATUS On
    ABSLT TPS(%) 11.4
    ENG SPEED(RPM) 1513
    CALC LOAD(%) 23.5
    MAF(LB/M) 1.72
    COOLANT(°F) 162
    IAT(°F) 61
    IGN ADV(°) 24.5
    ST FTRM1(%) 0.0
    LT FTRM1(%) 0.0
    VEH SPEED(MPH) 0
    FUEL SYS 1 OPEN2
    FUEL SYS 2 N/A
    EQ RATIO11 1.000
    OBD2 STAT CA
    @ medium acceleration in neutral
    FRAME: 6 TM: 19.2
    MIL STATUS On
    ABSLT TPS(%) 13.3
    ENG SPEED(RPM) 2108
    CALC LOAD(%) 23.9
    MAF(LB/M) 2.39
    COOLANT(°F) 163
    IAT(°F) 61
    IGN ADV(°) 31.0
    ST FTRM1(%) 0.0
    LT FTRM1(%) 0.0
    VEH SPEED(MPH) 0
    FUEL SYS 1 OPEN2
    FUEL SYS 2 N/A
    EQ RATIO11 1.000
    OBD2 STAT CA
    @ Dead miss, cannot gain more RPM, complete MISS, Blinking
    CEL and hard hard miss...
    FRAME: 8 TM: 25.6
    MIL STATUS On
    ABSLT TPS(%) 16.1
    ENG SPEED(RPM) 3071
    CALC LOAD(%) 27.8
    MAF(LB/M) 3.79
    COOLANT(°F) 163
    IAT(°F) 59
    IGN ADV(°) 29.5
    ST FTRM1(%) 0.0
    LT FTRM1(%) 0.0
    VEH SPEED(MPH) 0
    FUEL SYS 1 OPEN2
    FUEL SYS 2 N/A
    O2S12(V) 0.000
    O2S11(V) 3.298
    EQ RATIO11 1.000
    OBD2 STAT CA
    Now reducing RPMS from Hard miss at higher RPM...
    FRAME: 9 TM: 28.8
    MIL STATUS On
    ABSLT TPS(%) 13.7
    ENG SPEED(RPM) 2491
    CALC LOAD(%) 20.0
    MAF(LB/M) 2.18
    COOLANT(°F) 165
    IAT(°F) 59
    IGN ADV(°) 30.0
    ST FTRM1(%) 0.0
    LT FTRM1(%) 0.0
    VEH SPEED(MPH) 0
    FUEL SYS 1 OPEN2
    FUEL SYS 2 N/A
    O2S12(V) 0.000
    O2S11(V) 3.298
    EQ RATIO11 1.000
    OBD2 STAT CA
  2. Dec 12, 2013 at 12:43 PM
    wesb
    wesb Active Member
    HOUSTON
    98 PreRunner
    Dont feel bad man, I have been chasing my code for 8 months now. $2,500 later I still havent solved it. I'm misfiring in #2 and#5, when hooked up computer and at high rpm, comp shows NO MISFIRES. BUt still throws code. i have replaced, wiring harness, spark plugs, coils, timing belt, cat convert, crankshaft pulley tightened, engine practically re-wired. And i cant figure it out.
    Brie likes this.
  3. Dec 16, 2013 at 12:20 PM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    I read and thought. Is 30 degrees ignition advance reasonable? Just an observation as I cannot measure mine and determine what mine is. Good luck. Thinking of your problem. Someone who knows answer this question.
  4. Dec 16, 2013 at 1:34 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I'm not a mechanic but from reading your post I would, and it's just a suggestion as it's what I would do...
    Find another mechanic, not the dealer...
    Replace that leaking water pump.
    Replace the timing belt and put it on right.
    Replace the coils, being barely within spec on the low range means they are going out of spec as they heat up. This is most likely your problem.
    Replace the plugs and wires.
    See if that does the trick.
    I would not touch the distributor. Unless it's loose and slipping, there's no reason for it to change
  5. Dec 16, 2013 at 3:20 PM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    According to the '96 service manual i have you should check the following things when those codes show up.
    Ignition System
    Injectors
    Fuel Line Pressure
    EGR
    Compression Pressure
    Valve clearance not to specification
    Valve Timing
    Mass air flow sensor
    Engine coolant temperature sensor.
    I see you have checked most of that. If you want to PM me with your email i could send you my .pdf repair manual. Might take you a while to get it, Its 95MB. You would never get it unless you have a fast connection.
    Maybe buy some of this stuff and hit every electric connection you can find.
    http://www.walmart.com/ip/CNC-QD-Electronic-Cleaner-11-oz/16817418
    Brie likes this.
  6. Dec 17, 2013 at 6:50 AM
    wesb
    wesb Active Member
    HOUSTON
    98 PreRunner
    Send some of that repair manual action my way if you don't mind?
    Brie likes this.
  7. Dec 17, 2013 at 7:55 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    OP,
    30 degrees of advance is normal. That's what I see when cruising.
    Your idle rpms seem high. My 2.7 hot idle is around 650.
    You do NOT have a distributor.
    Have you ruled out bad gas? Plugged exhaust? plugged cat?
    What was your compression ( in PSI ) ?
    I think, that as far as the timing marks are concerned, so long as both cams and crank show TDC, and the #1 piston is at the top, that should be OK. (however, you should know, I have no personal experience with this motor)
  8. Feb 28, 2020 at 4:55 PM
    Cmonroe1
    Cmonroe1 New Member
    I’m hoping to resurrect this thread as I have the exact same problem, was there ever any solution to this from the OP? Or has anyone else experienced this issue? Please help!
    Black DOG Lila and Hobbs like this.
  9. Feb 28, 2020 at 5:07 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    OP has not been seen on TW since 2013. This thread was his last post.Start a new thread. Good luck.:thumbsup:
    And
    Welcome aboard new member.:D
    Hobbs likes this.
  10. Feb 28, 2020 at 5:12 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I recommend you start your own thread to avoid any confusion.
    Black DOG Lila likes this.
  11. Feb 29, 2020 at 8:04 AM
    Glamisman
    Glamisman Well-Known Member
    you are not going to like my sugestion... take it all the way apart down to the cam belt gear on the crankshaft and pull the gear off and look at it carefully. It is not supposed to move at all on the crankshaft and make sure that all of the teeth on it are on it or bent. Sometimes the goove in the gear gets worn and the gear shifts slightly during running and it will give you the sypmtoms you are describing. Yeah pain in the ass just to do a check. When you get the belt on and timed, rotate the crank 2 times by hand and verify the timing marks again.
  12. Feb 29, 2020 at 10:59 AM
    1997tacomav6
    Denver
    I had this problem once and it was related to the coil packs there was no way to test them they tested good but they would fail at a certain RPM range intermittently it took me a year to figure it out by replacing all the coil packs,
    I never got a code and the dealer couldn't figure out what it was either.
    So I replaced the spark plugs and the coils and the spark plug cables and that solved all my problem.
    Knock sensors if they're not OEM might cause a problem to
  13. Feb 29, 2020 at 11:31 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I had a similar symptom. High RPM but only noticable under heavy load. Turns out I had corrosion on the secondary side of my ignition coils from ingress of moisture into thr spark plug wire to ignition coil boot. The high resistance was melting my spark plugs to a nub after 10k miles.
    I replaced the coils (still tested good), plug wires (tested good) and spark plugs & it remedied the problem.
    robertjohnsonjr and 1997tacomav6 like this.
  14. Jan 28, 2021 at 6:16 AM
    denimdan73
    denimdan73 Well-Known Member
    2022 TRD Off Road DCSB
    Pro Skid Plate - Lone Star Knock Off Trail Edition Lift - DIY - Toyota Parts
    Hey Folks!
    New member here, wanted to say thanks!
    I had the same problem, multiple misfires, changed plugs and wires.
    The problem was the Crank Position Sensor and wouldn’t throw a code. It would only show a problem when it was actually misfiring at 3200 RPM.
    Replaced the CPS and we’re good to go!
    Thanks again,
    DenimDan
    1999 Tacoma V6, 250k Miles
