I need help diagnosing this problem real quick before I take it to a mechanic.
Discussion in 'General Tacoma Talk' started by puloverhoodie, Feb 1, 2025.
  1. Feb 1, 2025 at 5:54 PM
    puloverhoodie
    puloverhoodie [OP] Member
    06 Tacoma V6
    I'm experiencing a strange issue with my car. Here it is when it's parked and I push down on the gas. Also (I have No video of it) When I accelerate from a complete stop, there's a noticeable grinding noise, and the car jitters and shakes quite a bit, especially between 1000 and 2000 RPM, right before it shifts gears. The shaking and grinding are less pronounced, but still present, if I quickly depress the gas pedal while already in drive. Once it shifts, the car seems to run normally. https://photos.app.goo.gl/8sqz2xnnvQnWUcjw8
  2. Feb 1, 2025 at 5:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll guess driveshaft ujoints and center bearing.
    puloverhoodie[OP] likes this.
  3. Feb 1, 2025 at 5:58 PM
    puloverhoodie
    06 Tacoma V6
    I'll look more into that than. Thank you for your quick response
  4. Feb 1, 2025 at 6:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In your video the truck isn’t even moving. So I can’t help with the acceleration issue.
    I hear what sounds like an exhaust leak.
    But it’s really hard to tell with that video.
