I need help from an alignment expert
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sblspawn, Sep 18, 2024.
  1. Sep 18, 2024 at 1:30 PM
    sblspawn
    sblspawn [OP] Well-Known Member
    I really need someone with knowledge on the subject to tell me how much negative camber I can get with a levelled truck and oem UCAs? I want to be between -3 or -4 camber.
  2. Sep 18, 2024 at 2:00 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Why negative camber?
    drizzoh likes this.
  3. Sep 18, 2024 at 2:04 PM
    sblspawn
    I hate the look of positive camber on these Tacomas. Besides in my own truck I've been running negative camber for years with 0 problems. Tires are in great shape!
  4. Sep 18, 2024 at 2:06 PM
    gotoman1969
    How much lift are you planning?
  5. Sep 18, 2024 at 2:09 PM
    sblspawn
    It's my wife truck. She has Prerunner with aa level kit, 1.5 lift. 285s tires
  6. Sep 18, 2024 at 2:13 PM
    gotoman1969
    Should be able to get some. But with only 1.5”’of lift getting the alignment within factory specs should be a non issue, so there would be no positive camber at all. Should be able to get 0 camber, 0-.05 toe and 2.5 positive caster pretty easily. When you play with the camber on these trucks caster will be affected directly.
    drizzoh likes this.
  7. Sep 18, 2024 at 2:14 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Aside from what the OP said, positive camber is generally not recommended. It can result can reduced handling stability and make the vehicle feel the steering is "floating" (not to mention negatively affecting the vehicle to sway and potentially roll over in extreme situations).
    Generally a small amount of negative camber can be beneficial, but will also change handling characteristics and adversely affect tire wear.
  8. Sep 18, 2024 at 2:17 PM
    sblspawn
    Technicians with knowledge about the subject are hard to find.
  9. Sep 18, 2024 at 2:26 PM
    gotoman1969
    As you adjust the caster you naturally get camber to go negative. With the minimal lift getting want you want should not be an issue. The only issue may be with the 285s depending on wheel choice you may need caster as high as you can get to clear the front cab mount, unless you plan on a cmc. So they will affect the camber number.
  10. Sep 18, 2024 at 2:27 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Given that the 2g is the same as the 3g underneath, camber at +1.5" of suspension lift should be easily correctable if you find a shop that knows how to adjust the eccentrics. The hard part is finding a decent shop as most just correct toe and send you on your way. Ideally camber should be between 0 and -0.5 degrees for the best tire wear and drivability. Unless this is a drift build or some hellaflush fitment truck with stretched tires, there is no reason to have -4 degrees of camber up front. Caster, on the other hand, is usually in the 2 degree range stock, but if you are larger tires you might see if they can increase it a bit in order to not rub on the cab when turning.
  11. Sep 18, 2024 at 2:30 PM
    gotoman1969
    I agree. It’s hard to find a good tech who’s willing to put in the effort to get alignments correct and especially if you’re asking for specific numbers.
    sblspawn[OP] and drizzoh[QUOTED] like this.
  12. Sep 18, 2024 at 2:31 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Why?
    Camber should be just slightly negative.
    Caster should be between 3-4*
    You’ll never get those numbers on stock UCAs.
    Rusty66 likes this.
  13. Sep 18, 2024 at 2:34 PM
    sblspawn
  14. Sep 18, 2024 at 2:40 PM
    sblspawn
    Interesting! I don't like the way toyota suggests these trucks should be aligned. When you look at the front of these tacomas, they look pretty silly with the positive camber. Even in the way the tires rub the pavement, it doesn't look like a normal thing to do. They don't look flat at all!
  15. Sep 18, 2024 at 2:41 PM
    gotoman1969
    With the 0 offset. You’ll need caster on the higher end to clear the cab mount. That will put camber into the negative, how much you’ll have to see. Personally I wouldnt run more than -.5 camber but that’s me.
    drizzoh likes this.
  16. Sep 18, 2024 at 2:41 PM
    sblspawn
    But it's only a level kit!?
  17. Sep 18, 2024 at 2:44 PM
    steveo27
    Pittsburgh
    You’re still lifting the front of the truck 1.5”
    And there’s not enough adjustability in the LCA cams to nail both these numbers.
    This is the reason why you see lifted Tacoma with positive camber
  18. Sep 18, 2024 at 2:45 PM
    gotoman1969
    You won’t get that much caster on the oe arms. Higher caster really helps with handling. That why many of us go to after market ucas. For example I run 4 degrees caster, -.5 camber and .05 toe in. You can’t get numbers like that on OE arms.
    drizzoh likes this.
  19. Sep 18, 2024 at 2:45 PM
    sblspawn
    I'll be happy with -3. My Tacoma has -3 and looks pretty good, although sometimes it looks a little positive due to the independent suspension and the unevenness of the roads.
  20. Sep 18, 2024 at 2:48 PM
    gotoman1969
    Is it lifted too?
