i need help from you guys ASAP please!!! (esp. carpenters)
Discussion in 'Garage / Workshop' started by TacoTitan11, May 6, 2012.
  1. May 6, 2012 at 6:29 PM
    gsxrdoug
    gsxrdoug 2009 X-Runner
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    Not sure about insulation? Oz can it be laid on top of the blown? If not pretty easy for them to vacuum old stuff out.
  2. May 6, 2012 at 6:29 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Sure , but not really the point when it comes to the insulation values
    You can only get R12 batt insulation in a 2x4 cavity
  3. May 6, 2012 at 6:30 PM
    OZ-T
    Peter North
    British Columbia
    What's in there now , blown in , right ?
  4. May 6, 2012 at 6:30 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    ok, if anyone else wants to chime in feel free, thanks everyone
  5. May 6, 2012 at 6:31 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    blown in is in there now
  6. May 6, 2012 at 6:31 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    one guy told me that if you put boards down and it presses the insulation down, it might affect the insulation down the road
  7. May 6, 2012 at 6:32 PM
    AK27
    AK27 Well-Known Member
    Oz knows what he is talking about and is a trust worthy source of info :)
  8. May 6, 2012 at 6:33 PM
    OZ-T
    Peter North
    British Columbia
    That's true
    Squashed blown in is not as effective
    They should elevate the floor
  9. May 6, 2012 at 6:33 PM
    gsxrdoug
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    fluffy is good. but you can probably run stringers to give you another 1" of height
  10. May 6, 2012 at 6:34 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    thanks Oz....i will mention it to the guy in the morning. if he doesnt do it right i will just cancel the job. i want it done 100% right
  11. May 6, 2012 at 6:35 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Is the blown in insulation above the ceiling joists (bottom chord)?
  12. May 6, 2012 at 6:36 PM
    OZ-T
    Peter North
    British Columbia
    Before you shit can him , keep in mind there are lots of ways of doing this stuff , as long as he has a plan to address the insulation problem and they aren't going to alter the trusses at all , it will most likely be fine
  13. May 6, 2012 at 6:52 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    thank you guys. right now the blown insulation is probably 6 -12 inches above the wood
  14. May 6, 2012 at 6:53 PM
    OZ-T
    Peter North
    British Columbia
    That's good
  15. May 6, 2012 at 7:06 PM
    #35
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    Oz, do you foresee any moisture issues? should i be concerned with that?
  16. May 6, 2012 at 7:10 PM
    #36
    OZ-T
    Peter North
    British Columbia
    Moisture issues generally are from two causes , roof leaks and warm , moist air mixing and condensating with cooler air in the attic .
    If you have no roof leaks and you don't vent bath or kitchen fans into your attic , the only thing to be concerned about is limiting your conditioned ( inside the house ) air into the attic , this comes down to properly detailed insulation and vapour barriers
  17. May 6, 2012 at 7:13 PM
    #37
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    excellent! thank you
  18. May 6, 2012 at 7:13 PM
    #38
    OZ-T
    Peter North
    British Columbia
    No problem , best of luck
  19. May 7, 2012 at 3:42 PM
    #39
    OZ-T
    Peter North
    British Columbia
    How did the meeting go ?
  20. May 8, 2012 at 7:42 AM
    #40
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    just for reference, ..i've walked around up in my attic (similar truss structure w/ 2x4 bottom chords), ...i holds my weight fine walking on chord to chord (i.e. more of a point-load), ...but the loose-fill insulation is generally piled much higher, ..and for good reason - w/ that type of insulation you'll need it piled loosely and high for it to work as intended (it's the air trapped between the fibers that helps impeded heat transfer)... matted down insulation is less effective than loosely-piled.... in some climate zones it may be an option to have the upper part of the area, the roof decking done w/ spray-on type insulation..?
    also, make sure your attic is vented (ridge vent, soffit vent system, ..or similar)..
