i need help!! fuse keeps blowing!
Discussion in 'Audio & Video' started by jayhud11, Feb 4, 2012.
  1. Feb 4, 2012 at 4:50 PM
    jayhud11
    jayhud11 [OP] Well-Known Member
    jason
    valdosta, ga.
    08 4x4 double cab
    okay, so i have two rockford fosgate t1 15 inch subs and a 2000 watt hifonics amp. and my fuse keeps blowing/burning up on my wiring kit. i had a 6 gauge wire and it kept burning up so i got a 4 gauge wire and the fuse burnt up again, can anyone help me on why it keeps burning up? thanks.
  2. Feb 4, 2012 at 5:30 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It sounds like you've got a short. Have you double checked the routing and insulation of ALL wires and sheathing of ALL connection points?
  3. Feb 4, 2012 at 5:32 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Ground it.
  4. Feb 4, 2012 at 5:32 PM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    is it going through the firewall/metal? Check for a rub through the jacket?
    Also, is it immediately blowing, or lasting any amount of time, on any of the fuses?
  5. Feb 4, 2012 at 6:11 PM
    jayhud11
    jason
    valdosta, ga.
    08 4x4 double cab
    i put the new wiring kit in last night around 7:00 and today at 5:00 my fuse was blown. only had it on for a combined of 30 minutes. ans yeah its going through a firewall and its grounded.
  6. Feb 5, 2012 at 6:24 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    how many amps is it rated for and how many amps is your system pulling is the question.
    but a 2000 watt amp on 6 gauge? my 1500 watt rms amp just got some new 2/0 :D
  7. Feb 5, 2012 at 7:27 AM
    mattg43
    Texas
    08 Prerunner SR5 DC
    Check for rub through on the wire jacket. It it is lasting for a period of time, its probably shorting.
    That, and what amps are you running, on what wire?
    Watts do not determine wire gauge...
  8. Feb 5, 2012 at 7:35 AM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    oh come on, more watts=more amperage pull
  9. Feb 5, 2012 at 10:37 AM
    Norton
    :facepalm:
    This ^^. Voltage, Current, Power, and Resistance are all related. Given that voltage should be a relatively constant 12V-13V in this application, increasing the Power output from the amp requires increasing the Current flowing though it. Larger diameter/gauge wire (i.e., lower Resistance) is required for the higher Current flow.
  10. Feb 5, 2012 at 1:29 PM
    mattg43
    Texas
    08 Prerunner SR5 DC
    You guys do know that the amplifier efficiency and amperage draw directly affect the wattage ouput, but output does not determine the other two, right?
    If you are comparing 2 amps, of the same topology, with different outputs, you can generalize like "more watts=bigger wire", but if giving advise, I generally find accurate information more helpful than generalizations.
    http://bcae1.com/
    Check #16 on the right side.
  11. Feb 5, 2012 at 3:11 PM
    jayhud11
    jason
    valdosta, ga.
    08 4x4 double cab
  12. Feb 5, 2012 at 8:41 PM
    pinktaco808
    pinktaco808 Hot Steppa
    run atleast 1/0 gauge wire and add another battery.
  13. Feb 7, 2012 at 12:44 PM
    06SR5canada
    Saskatchewan
    06 dblcab SR5
    Or add up the fuses on your amps and buy the proper size?
  14. Feb 7, 2012 at 12:50 PM
    Aw9d
    Aw9d That one guy
    Az
    what wire kit are you using? For a 2000 watt amp, i'd be in the 0g wire to play it safe.
