I need help. Getting lift as I speak!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tac11, Mar 25, 2016.
  1. Mar 25, 2016 at 12:23 PM
    Tac11
    Tac11 [OP] Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Ok so I went to two auto shops and I want a 3 inch lift on the front of my 2011 double cab which has trd sport 17 inch wheels. I am debating of getting the leveling kit from this shop which is 550 idk the brand or buying pro comp or blistin500 as I seen here on threads. I will be keeping the stock rims for now but will increase the tire size to the biggest possible without running and having enough clearance. My question to you guys is where is the cheapest place for blistin or pro comp and what size of tire will do the clearance. Thanks in advance :) also ride quaility is a plus to me. I love my smooth riding truck
  2. Mar 25, 2016 at 12:52 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    protip
    slow down, back out of getting a lift today
    research this for a month longer, then decide
    Bagman, digitaLbraVo, Kyitty and 8 others like this.
  3. Mar 25, 2016 at 1:09 PM
    Monster1088
    Monster1088 Active Member
    Arizona
    2019 DCSB OR Tacoma
    You really need to do more research
  4. Mar 25, 2016 at 1:10 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    He can't slow down! Getting lift as he speaks!
    teamfast and ChadsPride like this.
  5. Mar 25, 2016 at 1:11 PM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
    I've been researching lifts since I joined. Still undecided lol.
  6. Mar 25, 2016 at 1:12 PM
    DrFunker
    DrFunker Well-Known Member
    :thumbsup:
    BlueHeli[QUOTED] and MicComa like this.
  7. Mar 25, 2016 at 1:12 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    On a budget, limit your lift to 2.5" to save money on UCA's (which you will need after lifting 3" to get a good alignment)
    Bilstein shocks paired with old man emu 885 coils will give a pretty good ride and 2.5" of lift.
    An add-a-leaf and bilstein 5100 shocks in the rear to kinda level the truck and improve ride.
    airrage likes this.
  8. Mar 25, 2016 at 1:14 PM
    Tac11
    Luis
    Haha I left guys, I have a buddy who says to get pro comp since he has it on his Silverado. I'm not sure since they say pro comp is not good?
  9. Mar 25, 2016 at 1:16 PM
    BlueHeli
    AZ
    None
    From what I know about those they are decent based on how high you go. Stay away from the 6 inch procomp unless you only want to fit bigger tires.
  10. Mar 25, 2016 at 1:16 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    I'd rely more on the thousands of tacoma owners on this site who have actual experience with tacoma suspension modifications.
  11. Mar 25, 2016 at 1:18 PM
    Tac11
    Luis
    Yea I'm just trying to get to estimate of a 3"
  12. Mar 25, 2016 at 1:18 PM
    Tac11
    Luis
    Blistin 5100?
  13. Mar 25, 2016 at 1:19 PM
    devkurf
    devkurf Member at Large
    midwest
    X2 If you are not sure its better to wait and get it right.
  14. Mar 25, 2016 at 1:23 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Here's what I went with. I love my set up. Zero issues. Rides like a cloud on and off road.
    5100's
    885's OME
    Top Plate Spacer Kit
    LR UCA's
    Carrier Bearing Drop Kit
    1.5" Cast Iron Blocks
    2" Toytec AAL With Zinc Plated Ubolts
    Removed Anti-Sway bar
  15. Mar 25, 2016 at 1:26 PM
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    ^^^ This..... Exactly what I did. Couldn't be happier. Also did the .25 spacer on drivers side to correct for taco lean. Right at 2.5 inches. Getting alignment tomorrow so we'll see what the numbers look like.
    ChadsPride likes this.
  16. Mar 25, 2016 at 1:33 PM
    Tac11
    Luis
    Awesome I'm leaning to the Bilstein. Would I need the 885ome or wats the purpose. And are the Bilstein a kit or actual shocks?
    MicComa likes this.
  17. Mar 25, 2016 at 1:38 PM
    ZRXDean
    Langhorne PA
    I'm no expert and everything I know I learned here....... but.....
    885x is the coil spring and Billstein is the shock absorber. Together they make the strut assembly. 885 spring has the proper spring weight for a double cab. there a re a number of spring options depending on what your going for.
  18. Mar 25, 2016 at 1:41 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Are you sure you've been doing your research? There's a good thread stickied in the suspension section that gives a lot of general info on what you need to know about lifts. Go read it. It will be 10 minutes well spent.
  19. Mar 25, 2016 at 1:43 PM
    BlueHeli
    AZ
    None
    I've already read a lot of the suspension forums. The issue is choosing the components that will work for what I want to do. I already know I want coil overs and new leaf packs and ball joint upper control are.
  20. Mar 25, 2016 at 1:53 PM
    Clearwater Bill
    Billy
    Largo Florida
    Level kit and 3" lift are not. even. close.
    Make up your mind.
    Consider how you use the truck 80% of the time, and build to that. If any building is actually needed.
    If you build to the 20% use, you'll spend more money and likely be unhappy with the other 80% of the time.
    MicComa, BlueHeli and Monster1088 like this.
