I need help. Getting lift as I speak!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tac11, Mar 25, 2016.
  1. Mar 25, 2016 at 2:28 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    This. Levelling kit is when you use spacers to bring up your front so its level with the back. Using spacers to get 3" of lift is not a levelling kit. Spacers are often called levelling kits. We know what you mean OP. Spacers are not the way to go though - even if you properly call them spacers rather than a levelling kit.
  2. Mar 29, 2016 at 7:00 PM
    Tac11
    Tac11 [OP] Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    @ZRXDean how was your alignment bro? I'm m getting that set up through headstrong for like $365 is that good or you got other recommendations? I also am considering the 1/4 spacer. How much would you recommend it? Is it that noticeable?
    Btw thanks everyone for their info! ;)
  3. Mar 29, 2016 at 7:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This is EXACTLY what I'm about to do. I got 4 bilstein 5100s, 885s, wheelers offroad 2" aal, and diff drop for about $625 shipped to my door.
    ChadsPride likes this.
  4. Mar 29, 2016 at 7:07 PM
    Tac11
    Luis
    Diff drop? I'm sorry for not knowing but what is that?
  5. Mar 29, 2016 at 7:09 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's a debatable topic on this forum is what it is. It adjusts the front differential to compensate for the lift. It helps to set the front CV axles to a better angle. This only applies to 4x4.
  6. Mar 29, 2016 at 7:09 PM
    Tac11
    Luis
    Oh okay. Thanks for the info.
  7. Mar 29, 2016 at 7:13 PM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    im lost to i've gathered stuff but still havent put kit on yet. because im not sure if there is anything else i need.
    i have 5100's front and back,front 5100 is on middle space which should be 1.75 i believe, coil springs, ad a leaf kit, diff drop, carrier bearing drop, angled shims for rear end.i dont know if i need longer brake lines or not, and dont know if i have to put all the stuff i have already on or just some of it. also dont k now if i need space for drivers side for famous tacoma lean.
  8. Mar 29, 2016 at 7:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you installed any of this?
  9. Mar 29, 2016 at 7:16 PM
    Doublecross
    Robbie
    New york
    Work in progress
    nope sitting in my brothers garage in deleware. im still trying to find out if i need anything else and what all do i put on lol
  10. Mar 29, 2016 at 7:17 PM
    Tac11
    Luis
    Should have a professional shop so my shocks and springs or can I do it w ease having little mechanical experience?
  11. Mar 29, 2016 at 7:18 PM
    Doublecross
    Robbie
    New york
    Work in progress
    struts and springs need a wall mounted spring compressor its easier
    Tac11[OP] likes this.
  12. Mar 29, 2016 at 7:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Alright. Here's what I'd do. Install the lift itself, without the spacer for the drivers side lean. I honestly don't foresee 1/4" making a difference to the naked eye. I'd also install the diff drop. Then get it aligned. After, drive up to highway speeds and see if you have any vibrations coming from the rear. That's when I'd start messing with the axle shims and carrier bearing drop because every truck is different. As far as brake lines, you don't need em.
  13. Mar 29, 2016 at 7:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Unless they come pre-assembled, I wouldn't mess with a spring compressor in my garage. A lot of mechanics shops have the proper compressors and can assemble your new ones for like $50.
  14. Mar 29, 2016 at 7:21 PM
    Tac11
    Luis
    Awesome so to put on my front Bilstein and ome I should pay around $50 or what's something reasonable?
  15. Mar 29, 2016 at 7:22 PM
    #35
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Just say hell with it and get Icons.
    DrFunker, Mully and Tac11[OP] like this.
  16. Mar 29, 2016 at 7:22 PM
    #36
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No no no. The $50 is if you take them your stock coilover and have them use their compressor to dis-assemble it and re-assemble your new bilstein and OME. To have someone install the lift completely would likely be a few hundred dollars.
    Tac11[QUOTED][OP] likes this.
  17. Mar 29, 2016 at 7:23 PM
    #37
    Doublecross
    Robbie
    New york
    Work in progress
    sounds like im better off picking up the kit and bring it back to ny and install in the garage at work it has a car lift in it lol long drive from deleware to new york on a new lift if i dont know how its gonna be lol
  18. Mar 29, 2016 at 7:24 PM
    #38
    Tac11
    Luis
    Thank you @EatSleepTacos I asked at shop and they said 200 but for adding spacers
  19. Mar 29, 2016 at 7:25 PM
    #39
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'd say so. It's really not too hard. There're enough tutorials on here and YouTube for you to make it through it.
  20. Mar 29, 2016 at 7:25 PM
    #40
    Doublecross
    Robbie
    New york
    Work in progress
    i put my struts and springs together at my brothers in his garage and new coil spring isolaters
