i need help installing some interior lights
Discussion in 'Lighting' started by Russell F, Apr 16, 2011.
  1. Apr 16, 2011 at 12:49 PM
    Russell F
    Russell F [OP] Well-Known Member
    Russell
    Madison Florida
    07 PreRunner SR5 Off Road
    Removed mudflaps, 14" shorty, weatherteck floor mats, interior floorboard blue led
    I got some blue led lights for the interior of my truck and it sais that I need to hook them up to the fuse box but I am having a problem finding the fuse box. Can anybody help out?
  2. Apr 16, 2011 at 12:54 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    If you can't find the fuse block you shouldn't be doing electrical work. Period.
  3. Apr 16, 2011 at 1:17 PM
    NaYoung
    NaYoung What about my Member???
    Florida
    2011 PreRunner SR5
    3/30/2011 Purchaced, Booster Seat, Child Restraint Seat, LED cockpit lights (amber), LED tailgate bar, 3rd brake light cover (Sock Monkey!), Tonneau Cover, Westin running boards, 17" wheels, Yakima Q bar system and landsharks
    I have to agree...:facepalm:
  4. Apr 16, 2011 at 6:58 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    I cant tell you specifically where it is since my first gen is probably different from your second gen. But your truck manual will show where the fuses are and how you can access them.
  5. Apr 16, 2011 at 7:46 PM
    NaYoung
    Florida
    2011 PreRunner SR5
    You have two fuse boxes. The easiest to access is behind the change holder (above your left knee when driving). Just pull it out to access, there's even a diagram on the back of the change holder to tell you what each fuse is for. When in doubt check the owners manual.
    If you're installing lights, just do a quick search of the threads, there's some good tips and pics.
    Make sure you find a ground so you don't set your taco on fire lol, by your original post doesn't seem like you've done this before. Good luck.
  6. Apr 16, 2011 at 10:18 PM
    Russell F
    Russell
    Madison Florida
    Yeah I found it earlier it only took a little bit of common sense to finally kick in and read the manual lol, but @NaYoung I have done it just not in a taco, my friend and I hooked some up in his f150 but it was a little easier to get to his fuse box
  7. Apr 17, 2011 at 8:35 PM
    LEDsolutions
    LEDsolutions Well-Known Member
    Personally, I would hook up whatever lights you have to a cig lighter! Tap into the red wire behind the cig lighter assembly then tap into the ground that is on the cig lighter assembly as well. Quick and easy! You can also mount a switch if you want.
    I have done this several times to have footwell lights, best thing about them is that they are on whenever the car is on! I guess you could also use one of those "add-a-fuse" thingies but then since you'd have to find the fuse location which goes on with ignition or is constant hot depending on your preference. Hope this helps!
