I need help on a good lift kit.
Discussion in 'Suspension' started by 2011Tacoma1293, Oct 14, 2011.
  1. Oct 15, 2011 at 2:50 PM
    #41
    2011Tacoma1293
    2011Tacoma1293 [OP] Well-Known Member
    Kevin
    Florida
    11 Tacoma 4cyl Barcelona red
    265/70/16
    I want to put 285/70/17 on it with some pro comp 7033's 17"
  2. Oct 15, 2011 at 3:12 PM
    #42
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Lots of trimming, and possibly a cab mount chop, and yes with a 285 tire on a 4 cylinder you might lose a significant amount of mpg's
  3. Oct 15, 2011 at 3:21 PM
    #43
    2011Tacoma1293
    Kevin
    Florida
    what is a cab mount chop?
    what kind of tire would you say would make look a little more beefy and make the tire stick out alittle from the fender?
  4. Oct 15, 2011 at 3:24 PM
    #44
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    You "could" but you get what you pay for in most cases. Stick with companies you know like Toytec, Wheelers or All Pro.
  5. Oct 15, 2011 at 3:37 PM
    #45
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Get the 5100's and set them @.85 along with the Elbach coils. You may be able to fit 285's but you will have to trim and remove your front mud flaps.for the rear go with a progressive AAL & 5100s. If I were you I would just go with a 265/75/16 tire so you wont loose too much MPG/power with your 4banger.
  6. Oct 15, 2011 at 3:48 PM
    #46
    2011Tacoma1293
    Kevin
    Florida
    is trimming the mud flaps hard at all?
    and what aobut taking them off?
  7. Oct 15, 2011 at 3:56 PM
    #47
    ColtsTRD
    Scott
    AZ
    trimming is not hard...could be done with a pair of snips...or you can take them off if your state permits it
  8. Oct 15, 2011 at 4:26 PM
    #48
    2011Tacoma1293
    Kevin
    Florida
    what is the difference between the progressive and the other one i guess?
  9. Oct 15, 2011 at 4:29 PM
    #49
    ColtsTRD
    Scott
    AZ
    progressive = smoother ride...its a longer AAL
  10. Oct 15, 2011 at 4:29 PM
    #50
    2011Tacoma1293
    Kevin
    Florida
    i was looking into the pro comp 7033 wheel in the 17 inch. what wheel do you think looks good and wont murder my mpg's?
  11. Oct 15, 2011 at 4:31 PM
    #51
    ColtsTRD
    Scott
    AZ
    dude, tire size is what effects your mpgs...not wheel! Anything larger than stock (tire) will effect your mpgs...the bigger you go..the worse it gets unless you re-gear...try searching dude! :cool:
  12. Oct 15, 2011 at 4:39 PM
    #52
    ColtsTRD
    Scott
    AZ
    Thats what I said...wheel really has nothing to do with it...example
    265/75/16
    265/70/17
    265/65/18
    all will yeild about the the mpgs...its the tire size and resistance (m/t or a/t) that will effect the mpgs
  13. Oct 15, 2011 at 4:53 PM
    #53
    2011Tacoma1293
    Kevin
    Florida
    so lets say i got the pro comp xtreme mud terrain. the fact that they are mud terrain will make me lose mpgs
  14. Oct 15, 2011 at 4:54 PM
    #54
    ColtsTRD
    Scott
    AZ
    thats correct...because of the road resistance due to the more aggressive tread pattern...what size tire are you looking at?
  15. Oct 15, 2011 at 5:00 PM
    #55
    ColtsTRD
    Scott
    AZ
    x2
  16. Oct 15, 2011 at 5:05 PM
    #56
    2011Tacoma1293
    Kevin
    Florida
    well i was looking at 285's but the fact that its a problem with the mud flaps and stuff im not sure. now you explained the the 265 thing to me i was looking at that but some m/t 265/70/17
  17. Oct 15, 2011 at 5:09 PM
    #57
    ColtsTRD
    Scott
    AZ
    Okay, like mentioned before trimming will be required with 285s...some things include the fenders, cab mounts and inner wheel well...its not that big of a deal. Just depends on what your comfortable with lol. Now, a 265/70/17 would look nice with a 3" lift for sure...especially the Good Year Duratracs...some 265s run a little larger than others...for example...I'm also running 265s and I have a 3 inch lift. I will be stepping up to 285s but Cortland on here has 265 Duratracs and their noticablly bigger...and the there the same size 265/75/16
  18. Oct 15, 2011 at 5:11 PM
    #58
    ColtsTRD
    Scott
    AZ
    Do what you want bud...its your truck! 285s really make these trucks look like tanks!
  19. Oct 15, 2011 at 5:15 PM
    #59
    2011Tacoma1293
    Kevin
    Florida
    i like tanks
  20. Oct 15, 2011 at 5:16 PM
    #60
    ColtsTRD
    Scott
    AZ
    MEEEEEE TOO!!! :cheers:
    I'm a cheap ass so i'm waiting for my 265/75/16s to wear out...then the 285/75/16 Duratracs go on :D
