I need help on my Bilstein Quest!
Discussion in 'Suspension' started by SuthrnTaco07, Oct 23, 2012.
  1. Oct 23, 2012 at 9:47 AM
    SuthrnTaco07
    SuthrnTaco07 [OP] Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    Ok.. I know its a long shot but I am on the search for these certain front shocks that I noticed were slightly different then your standard Bilstein 5100.
    As you can see below is your standard Toyota Tacoma 05+ Front adjustable coil over shocks.
    Now look below and in this picture is the 05+ Toyota Tacoma 4" Lift kit from RCD and they seem to offer a different set of 5100's with it...
    Now I know this could be a generic picture they use just to represent suspension components but it really doesn't look like it. Is there anyone out there who can enlighten me and tell me where I can get those 5100's?
  2. Oct 23, 2012 at 9:53 AM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Do they offer part numbers for the components they offer in the kit? If not, maybe contact them and find out for sure. I checked the bilstein catalog but didn't find a 4" application front 5100.
  3. Oct 23, 2012 at 9:57 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Why do you want the longer 5100's?
    They won't fit without RCD's 4" drop bracket lift.
    But, from RCD's install instructions for that lift, here's the old and outdated bilstein part number. F4-BE5-E122-T0
    If you need them, call RCD.
  4. Oct 23, 2012 at 12:23 PM
    SuthrnTaco07
    Kyle
    Huntsville, AL
    None
    I have a drop bracket kit but my suspension is wore out and I was just wanting a longer version of 5100's to set some 886's on.. I'll try giving them a call but for some reason when I try to go to RCD's website I can't get it to pull up..
  5. Oct 23, 2012 at 12:42 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Doubt those will work with your PC 6" lift. Spend the $ on the King coilovers for lifted application.
  6. Oct 23, 2012 at 12:57 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Or Icons. Yeah, not so sure that those bilsteins would work properly on the Pro-Comp Lift. They Drop-Bracket design and amount is different I think.
  7. Aug 26, 2018 at 5:45 PM
    Tuby07
    Tuby07 Active Member
    Central California
    2007 TACOMA DCLB SPORT
    Really old post but did some research and was told they fit or can replace my DB spacer lift. Was wondering did you go that route on yours, if so, where did you buy them. Cheapest I found was $289/pair before shipping.
