I NEED HELP on removing Spindles!
Discussion in 'Suspension' started by WRrider450, Feb 18, 2011.
  1. Feb 18, 2011 at 4:35 PM
    WRrider450
    WRrider450 [OP] Well-Known Member
    Torranceish
    09 TRD Off-Road 4x4
    13" Wicked Flow Muffler
  2. Feb 18, 2011 at 4:38 PM
    4X4_TRD
    4X4_TRD Well-Known Member
    Justin
    San Diego, CA
    '03 Jeep RUBICON
    No front sway bar (does that count?)
    Thread that nut back on but leave it loose. Give it a good whack with a rubber mallet. Both mine came off fairly easy. Good luck!
  3. Feb 18, 2011 at 4:39 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    it can be a little tight, but it will come off as long as you took off the castle nut. try hitting the UCA up with a mallet. spraying the bolt with wd 40 or pb blaster or something like that will help too
  4. Feb 18, 2011 at 4:40 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    The correct way is with a ball joint seperator. It is a tapered fit. First you should strap the spindle to the UCA with something so they don't just fall out and break the brake lines. Then use a hammer and give the spindle short sharp strong blows on the flat spot right next to the ball joint. They will pop out after a few blows. remember when you put them back together you will need to push the ball joint back into the spindle as far as you can get it and finger tighten the castle nut. If you rely on the castle nut to bring the two together the ball joint will simply spin and you will damage the grease boot. This will be pretty tough because it will take a lot of down pressure on the UCA to get them all the way together since the UCA is preloaded. Or you can loosen the UCA bolt just remember to preload the suspension before you retighten the UCA bolt.
  5. Feb 18, 2011 at 4:43 PM
    WRrider450
    Torranceish
    09 TRD Off-Road 4x4
    First of all thanks for your help. Now back to the issue at hand...I took the bolt off and then loosely wired the spindle to the uca. And I did wacked it several times with a rubber mallet but it is really freaking tight and isn't budging. Ill try spraying it with some WD40.
  6. Feb 18, 2011 at 4:44 PM
    PreRunnerSeth
    Apex, NC
    You need to hit the spindle next to the ball joint with a real metal hammer. Its the shock of the blow that gets it to come apart.
    If you are looking at the spindle you will see where the ball joint connects then there is a right angle where the metal goes down to the rest of the spindle. Hit it on that flat spot there with a metal hammer. Like i said, short sharp blows.
    ***DO NOT HIT THE BALL JOINT STUD WITH THE HAMMER***
  7. Feb 18, 2011 at 4:48 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    oops....
  8. Feb 18, 2011 at 4:53 PM
    4X4_TRD
    Justin
    San Diego, CA
    '03 Jeep RUBICON
    You're just installing new 5100's? Removing the sway bar might be a lot easier. I never had to disconnect the UCA's to install coils.
  9. Feb 18, 2011 at 6:21 PM
    beartrack
    beartrack Well-Known Member
    Nova Scotia
    SR5
    toytec coilovers, 2"aal's, LR UCA's hood struts, weather tech mats
    What he said. Just be careful not to hit the rubber on your balljoint or you will cut it.
  10. Feb 18, 2011 at 6:37 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  11. Feb 18, 2011 at 10:52 PM
    WRrider450
    Torranceish
    09 TRD Off-Road 4x4
    Thanks for all your helps guys! I got the spindle off, and now the sway bar is in the way so Im taking that off too :/
  12. Feb 18, 2011 at 10:55 PM
    WRrider450
    Torranceish
    09 TRD Off-Road 4x4
    Oh and one more thing...how in the hell am I supposed to torque the three bolts on top of the shock hoop? especially the one in the back
  13. Feb 19, 2011 at 6:21 AM
    KenLyns
    Belly of the Beast
    1. Crow's foot extension.
    2. Wrench extension.
    3. Do some calculations to figure out the required bolt stretch to get 70% of yield strength, multiply by thread pitch to figure out the required fractions of a turn after rundown.
    3. "Eeeeeh, that's about right..."
