I need help picking gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05tacoSPORT, Feb 18, 2011.
  1. Feb 18, 2011 at 10:29 AM
    05tacoSPORT
    05tacoSPORT [OP] Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Ok. So uncle Sam just gave me the cash. I have a v6 auto, running 285/75/16. With a lot of extra weight on the truck. I also pull a bass boat in the summer and a 4 wheeler in the winter. And towing any one of the two sucks. The truck isn't my DD and sits most of the time. Currently at 15.5 MPG not towing. $2000 will get me 4.88 and a ARB locker. This would help on the towing part and I should be running around 2600rpm at 70, not towing. Should I do this or save the cash? And would my MPG go up if I drive easy.
  2. Feb 18, 2011 at 10:48 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Pre runner or 4x4?
    You can't regear a 4x4 with an arb for only 2k unless you do all the work yourself.
    Sounds like 4.56 would meet your needs.
  3. Feb 18, 2011 at 10:54 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    4x4 and locked in the rear only. 3rd member swap and install myself. I want lower gears for offroad use and also have the ability to tow without my tranny screaming trying to keep a steady speed
  4. Feb 18, 2011 at 10:58 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Lol, I know this. Just not gonna lock the front
  5. Feb 18, 2011 at 11:03 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You're gonna total out around 2500 all said and done.
  6. Feb 18, 2011 at 11:10 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    $2,146.00. For 4.88
  7. Feb 18, 2011 at 11:17 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    ARB are $850 a pop. Im getting the r-129 for the rear only
  8. Feb 18, 2011 at 11:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If its a DD, 4.10's will get the truck near stock, while the 4.56's will over gear it a bit.
  9. Feb 18, 2011 at 11:33 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Justed talked to chase. 4.56. Is what I need. 4.88 require a new $400 clamshell. Chris 4x4 it's not a DD.
  10. Feb 18, 2011 at 11:38 AM
    Manwithoutaplan
    ID
    Get 4.56 gears and get the gears from East coast gear supply.
  11. Feb 18, 2011 at 12:50 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK. You talked to them, so I'm guessing you're not forgetting anything:
    Gears (front and rear)
    Install Kit (front and rear)
    Labor to build the 3rd member (front and rear - but not to install them in your truck)
    ARB Locker (1)
    ARB Air compressor
    Shipping (including returning the original 3rd members)
  12. Feb 18, 2011 at 12:52 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Anyhow, to the original question - when I regeared my 94 F150 from 3.31 to 4.10 (31" tires) I got a little bit BETTER gas mileage for around town stop and go driving. Not to mention the truck drove better.
  13. Feb 18, 2011 at 1:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x1000:thumbsup:
  14. Feb 18, 2011 at 5:40 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    OK here is what is on the list
    4.56-NG T100/Tacoma non locking diff​
    4.56 Ring and Pinion​
    Master Install Kit ​
    Diff Build Labor​
    ARB RD-129​
    Solid Spacer with shims​
    8" Reverse Clamshell with 4.56 Thick Ring and Pinion​
    8" Clamshell Add Tube CV Shaft Seal​
    Clamshell Pinion Seal​
    Front Diff Labor​
    Shipping both ways Total=$2,222​
  15. Feb 18, 2011 at 5:47 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    I already have the ARB compressor
  16. Feb 18, 2011 at 5:50 PM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    Rear is $1596 and the front is $550. $152 for shipping round trip.
  17. Feb 18, 2011 at 6:37 PM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    I tried (actually did) something very similar with a different vehicle thinking I'd be at about 2500 to 2700 RPM at 65 or so. I went with 4.56 and 32" tires. I ended up turning right around 3K at 65. So I'd just check and recheck the overdrive gear ratio / tire size if I were doing it again. Great on the low end but too tall for highway trips really.
