I need help picking out new Head Light Bulbs
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Apr 2, 2014.
  1. Apr 2, 2014 at 6:36 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Got some smoked headlights from ebay and the current bulbs arent cutting it. I need something bright that wont break the bank and wont blind the other drivers.
    Option 1: Brighter bulbs
    http://www.amazon.com/Sylvania-Silv...=UTF8&qid=1396488710&sr=1-1&keywords=9003/HB2
    Pros: Cheap(ish) and bright
    Cons: Dont last long and need to be replaced frequently
    Option 2: HID bulbs
    Something like this: http://www.amazon.com/XENTEC-Conver...8&qid=1396488392&sr=8-5&keywords=9003+hb2+hid
    -Lasts longer
    Cons: Dont like the blue light look
    Option 3: Led bulbs
    Pros: Last long (dont know how bright they get)
    Cons: Expensive and probably too bright
    Something like this: http://www.amazon.com/Newsun-1800lm...&sr=1-11&keywords=9003/HB2+Led#productDetails
    Option 4: Retro fit mod... Way to expensive :mad:
    Thoughts?
  2. Apr 2, 2014 at 6:41 PM
    Ghosted
    Ghosted Member
    2000 Tacoma Prerunner
    I would go with the HID. If you have to replace the sylvania ones frequently then you will definitely end up spending more in the long run. Plus, i like the blue tint to them. Thats my opinion.
  3. Apr 2, 2014 at 10:24 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  4. Apr 3, 2014 at 8:57 AM
    Brad H
    Brad H Well-Known Member
    Lisbon Falls, ME
    01 4x4 SR5
    Deck Plate, Marlin Crawler Rear Bumper, All-Pro APEX Front Bumper and Skids, Bilstein 5100s w/ Eibach Springs front, Wheelers 5Pak w/ OME, '01 Tundra Front Brakes, CBI Bolt-on Sliders, More to come
  5. Apr 3, 2014 at 11:36 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  6. Apr 3, 2014 at 12:59 PM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
  7. Apr 3, 2014 at 5:10 PM
    OutlawJas
    OutlawJas Well-Known Member
    Southeastern PA
    04 Stock Ext cab TRD 4x4
  8. Apr 6, 2014 at 6:45 PM
    Len04Taco
    Len04Taco Well-Known Member
    Len
    Stow, MA
    04 SR5 Red
    Do these Osram bulbs need the upgrade of the headlight wiring harness?
    Len
  9. Apr 6, 2014 at 7:38 PM
    OutlawJas
    Southeastern PA
    I didn't upgrade anything. Just plugged the in and went.
  10. Apr 6, 2014 at 7:41 PM
    Norton
    No. They're a direct replacement for OEM and require no wiring changes/upgrades.
  11. Apr 6, 2014 at 7:45 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    6-8 months and mine were done.
    That's driving to work every morning with the lights on (45-60 minutes).
    IIRC, I was using these during the summer months, so I was not running lights on the way home in the evening.
    PLEASE PLEASE PLEASE do not do drop-in HID.
    Not only are they illegal, they scatter glare badly and blind oncoming drivers (and drivers in front of you). In California, CHP is cracking down on them.
    They are dangerous and inconsiderate (and yes, I used to use them until I spotted my lights on a wall and saw how bad they were).
    Do a proper projector retrofit if you want HID (and it does not have to be blue):
  12. Apr 6, 2014 at 7:54 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    True story....HID's are meant to be used in projector lens assemblies with a shroud for high/low beam,or a dual projector assembly with one high and one low. any other use of them is completely inconsiderate,even with smoked lenses you'd still blind the hell outta people. If you do a retrofit,you can choose which temp range to get them in and so choose a color from yellow to violet through the spectrum range.
  13. Apr 6, 2014 at 8:05 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    BTW: The shot above are the TRS D2S projectors, running the Philips 4300k lamps.
    These are the same lamps that many automakers use in their OEM systems.
    I would not go more "blue" than 6000k... and even that is pushing it.
    8000k is WAY too blue and starts seriously cutting back the usable light.
  14. Apr 6, 2014 at 8:14 PM
    F75gunslinger
    Christian
    Rochester,NY
    I've got 6000k in the bike....they rock ! they'll make a set of silverstars disappear..and that's sayin' somethin'.
