I need help please !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBTWENTYTWO, Mar 17, 2014.
  1. Mar 17, 2014 at 9:37 PM
    JBTWENTYTWO
    JBTWENTYTWO [OP] Well-Known Member
    2011 Prerunner
    Cooper Discover STT tires 285/70/R17 (33s) Procomp 7032 matte black wheels 17x9 -6 offset. Front lift: Bilstein 5100 Adjustable Shocks set at 0. OME 885x coils. Rear lift: Bilstein 5100 shocks. 1.5 inch 3 leaf progressive. I still have stock UCAs but plan on getting aftermarket ones later. I ordered the shocks and coils from headstrong offroad and the 1.5 inch 3 leaf progressive from Wheelers Offroad. 50" Radius Light bar (From Sidetracked Offroad) Mounts from Relentless Fabrication.
    I'm just looking for some feed back and if I'm going to have any trouble with the setup I plan on running. I have a 2011 prerunner that I'm going to be purchasing new tires and rims here shortly as well as a 3 inch lift kit. For tires I'm going to do 275/70/R18 Goodyear Durtracs with Fuel Krank wheels. Also for the lift I'm going to do the 3inch OME. Am I going to have any problems running this? Like rubbing etc.. I need some help before I purchase anything!
  2. Mar 17, 2014 at 9:43 PM
    beedub
    beedub Well-Known Member
    Colin
    Vacaville, California
    '14 ACab Offroad
    Possibly slight rubbing with front mudflaps and pinch weld, if I remember correctly. Nothing a little trimming can't fix, probs. Talk to your local mechanic if you are unsure of doing it yourself.
  3. Mar 18, 2014 at 6:21 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    As above probably will have to cut a bunch of plastic depends on the offset of your wheels. Cab Mount Chop maybe just depends but I did it myself in my driveway and if you need guidance pop me a pm as it isn't difficult at all and want hurt anything. With the 3" lift you may not rub any. I wouldn't be too concerned about it but you will need new upper control arms to get your alignment correct.
  4. Mar 18, 2014 at 8:17 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Wheels with a '0' offset /BS of 4.25-4.5" should clear the UCAs. CMC will probably be needed especially since Duractracs in that size measure over 33".
