I need help... Quick, please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt45648, Apr 1, 2009.
  1. Apr 1, 2009 at 6:14 PM
    matt45648
    matt45648 [OP] Well-Known Member
    im in the middle of removing my strut assembly's... I have removed every nut... The spindles will not drop free from the ball joints... Anyone??
  2. Apr 1, 2009 at 6:18 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    hit the control arm where the ball joints go through them with a hammer. leave the nuts on the ball joints to protect the threads, and to keep the spindle from falling off when they come loose.
    what lift are you installing?
  3. Apr 1, 2009 at 6:19 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    hit the control arm with a hammer (rubber mallet) it will come out with a few good hits.
    edit: Dang too slow
  4. Apr 1, 2009 at 6:26 PM
    matt45648
    I have litterally beat the holy hell out of it.... Not budging
  5. Apr 1, 2009 at 6:29 PM
    Lentsnh
    Chris (Chris4x4) or one of them will chime in, in a few minutes or so. They will help you out more than I can.
    Like what jaxchrisfla asked. What are you putting in? Spacers,lift?
  6. Apr 1, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you trying to remove the UCA baljoint?? Did you remove the sway bar endlink?
  7. Apr 1, 2009 at 6:54 PM
    jaxchrisfla
    flooriduh
    lots
    if your only putting in say a RevTek kit, you should not have to remove the spindle to get the strut assembly out.
  8. Apr 1, 2009 at 7:19 PM
    matt45648
    5100's
    My grandpa finally got it... Thanks for the help guys...
  9. Apr 1, 2009 at 7:25 PM
    Lentsnh
    No problem bro. Glad we could help
