I Need Help!
Discussion in 'Wheels & Tires' started by skidynastar33, Dec 20, 2009.
  1. Dec 20, 2009 at 8:52 PM
    skidynastar33
    skidynastar33 [OP] Active Member
    kyle
    seattle
    09 taco
    all i can say is what a weekend! so first put on some LR ucas. that went good and thats about it. took it to get aligned and then on the way to get new tires noticed it drifted left. looked at the alignment sheet and wasnt pleased.
    left right
    -.03 camber -.15
    1.89 caster 2.43
    .06 toe 0
    front
    cross camber .12
    cross caster -.54
    left caster isnt even close to the 2.4 i asked for and the front cross camber says it not even within specs on the sheet he gave me. so question one is do the others look alright?
    next was tires, i was getting 285/75/16 wrangler duratrac and my 09 taco with a 3" ome lift plus now the lr uca and i was putting the tires on my stock wheels. when they went to put them on they couldnt even get them on cause they hit the uca, they tried putting on a 265/75/16 and they hit a little too. so what do i need to do to get them to work??? i think i have heard of wheel spacers but am not sure about them? i would like to use the stock rims cause i dont want to spend more money but if i do get new rims what offset would i need?
  2. Dec 20, 2009 at 8:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    265/75s rubbed? Thats what I'm running with a 3" lift and I have stock ucas (i'm getting the LR UCAs aswell) You would think that they'd rub on the stock and not the after market...weird
  3. Dec 20, 2009 at 9:03 PM
    skidynastar33
    kyle
    seattle
    09 taco
    i know thats what i would have thought too
  4. Dec 20, 2009 at 9:12 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    well first i would get the alignment issue resolved. you should not be rubbing the 265s at all. second, with the 285s you will probably want to get some spacers. i went with trail-gear.com spacers 1 1/4 wide and with my stock wheels i ran 305/70/16s without any problems. they sell them for around $80 a pair and they are high quality.
  5. Dec 20, 2009 at 9:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Get the alignment fixed.
  6. Dec 21, 2009 at 6:38 PM
    skidynastar33
    kyle
    seattle
    09 taco
    les schuab said they leave the left caster lower then the right so they dont catch in ruts or something. i wasnt totally following. but they said get the tires put on and they would fix it. so what is the offset i need with that size tire. im looking at rims now.
    does anyone know a good black alluminion wheel less than $125? im searching through now put this would spped up my process.
    thanks
  7. Dec 21, 2009 at 6:45 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Les Schwab throws around their slogan: "If we can't guarantee it, we won't sell it." I'd go back and put them to work.
  8. Dec 24, 2009 at 9:34 PM
    skidynastar33
    kyle
    seattle
    09 taco
    one more question, so im looking at moto metal 951's wheels and am wondering the pros and con and differances of going with the 16 x 8 with 4.5bs or the 16 x 9 with 4.5bs and -12 offset?
    thanks
  9. Dec 25, 2009 at 1:56 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    May have to grind your calipers slightly with these though.
  10. Dec 28, 2009 at 3:11 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Check your LR UCAs to make sure they're on correctly. It's possible to swap the gold bracket. They should be flat side out (with the SPC stamp showing):
  11. Dec 29, 2009 at 6:30 AM
    skidynastar33
    kyle
    seattle
    09 taco
    thanks i am going to check now
  12. Dec 29, 2009 at 9:53 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    thats bs.im running a 265 on stock wheels and no where near rubbing my uca.something is out of wack for sure.
