I need more power...
Discussion in '4 Cylinder' started by T-Sali12, Aug 16, 2009.
  1. Aug 16, 2009 at 9:58 PM
    T-Sali12
    T-Sali12 [OP] Member
    98 2.4L Standard Cab
    Fabtech 3.5" performance lift, 3" body lift, full magnaflow exhaust, K&N cold air intake, cobra PA, pioneer head unit ans speakers, 2 bazooka 10'' subs with 400w amp
    I have a 98 2.4L Taco and i want to lift it more put bigger tires, but I want to too give it a little more power before, Any suggestions???
  2. Aug 16, 2009 at 10:10 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Slap a turbo on it or you can get some aftermarket headers.
  3. Aug 16, 2009 at 10:15 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    V6 or V8 swap.
    Or turbo/supercharger are your best options
  4. Aug 17, 2009 at 4:55 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    power increases on a 4 banger Yota are hard to come by you may be better off regearing and that will keep the same feel when you get bigger tires. Otherwise power adders are your only option.
  5. Aug 17, 2009 at 4:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Trade it in....and get a 6 cylinder and even 4WD.
  6. Aug 17, 2009 at 6:27 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    check in the gen 1 part too, they might have good threads on the topic, mine is gen2 2.7. While i think a cai might not help my engine , it might actually help yours.
    this list might help for power, its not from experience though
    180 degree thermostat
    cold air intake, performance chip if available, elec. cooling fan(this could be a good one), headers (another good one), performance exhaust( i dont like the loudfart ones).
    Pick one , research it for your year, if it sounds no good , move on, if it pans out .. have fun.
  7. Aug 19, 2009 at 1:16 PM
    boutym
    boutym Member
    NY
    Get yourself a turbocharged Allison motor for that puppy.
  8. Aug 19, 2009 at 2:31 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    get some good headers and try a CAI, it worked on mine (according to K&N it would give your engine a 6-7 HP boost with the FIPK one) and i'm gettting new headers sometime this fall. But you would def be better off with a turbo or SC if you have the money but a 2.4l just won't really ever have the power to have really big tires or lift on it
  9. Aug 21, 2009 at 8:17 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    i put 31/10.50s on my truck and i am getting 4% better fuel mileage and lower rpms. I havent been 4x4ing yet but ill bet you the truck is even better.
  10. Aug 25, 2009 at 1:28 PM
    stock02
    stock02 Member
    Moreno Valley
    02 std cab, short bed
    I've also been thinking about doing a lift for some 31x10.0 and I also have the 2.4L. Will it really make that much of a differance even if I gear it? I know I can do a V6 swap, but I think I would just get a taco WITH a V6 in it. I don't know, I love my taco too much, lol
  11. Aug 25, 2009 at 5:31 PM
    RideFast
    Jesse
    Tacoma
    if you have an 02 taco 4x4 you should have the 2.7L.
    Like I said the 31 10 50 tire made an awesome difference to my truck. my power was not affected! Do it, i found my tires on craigslist.com
  12. Aug 30, 2009 at 5:46 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    I have most all the Bolt on stuff you can do plus im regeared and wish I had just done a Supercharger to start with.
    The Gearing makes a big difference in the Auto but most the other bolt on stuff was pretty minor.
