I need new shocks, what lift is this?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Necro, Jun 7, 2013.
  1. Jun 7, 2013 at 8:37 PM
    Necro
    Necro [OP] New Member
    Norfolk Va.
    97 Tacoma
    Suspension and body lift.
  2. Jun 7, 2013 at 8:50 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Trailmaster 6" aka Trail Disaster
  3. Jun 7, 2013 at 8:51 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Don't buy that lift get a pro comp if you want to go 6 inches
  4. Jun 7, 2013 at 9:19 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I think the lift has already been bought and installed and the OP is looking to replace the shocks.
    OP, no idea but your truck may require some good lovin' with a replacement of the front suspension. I'm guessing it is going to be hard to source replacement shocks and the lift design looks sketchy at best.
  5. Jun 7, 2013 at 9:22 PM
    Greensystemsgo
    Greensystemsgo She looked 18...
    Dirty Nickers
    Peoria, AZ
    99' extended cab
    Bone Stock
    dear op, best bet would be to meet up with an wheelin' shop to get proper measurement shocks with your proper sized bushings.
    Unfortunatly that kit is gonna be in there for good, unless you can come accross a new crossmember as the old one was cut out. ALSO, ditch the body lift.
  6. Jun 7, 2013 at 9:23 PM
    MGMTacolover55
    Orygun
    floor Mats
    He could always get a custom cross member and
  7. Jun 7, 2013 at 9:27 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    99' extended cab
    Bone Stock
    who makes a custom cross member to maintain stock ifs componets on a tacoma? unless he relifts it, but that is still counter productive.
  8. Jun 7, 2013 at 9:28 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    Idk man but that lift looks hella sketchy
  9. Jun 7, 2013 at 9:32 PM
    taco terror
    taco terror got 5VZFE?
    Austen
    North Carolina
    clean machine 96
    AR Baja wheels, 33 BFG ATs, 4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, Line-x
    Good heavens, what has the previous owner done to that poor truck? You could change your spark plugs through that wheel well.
  10. Jun 7, 2013 at 9:32 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    That lift is bizzare. Can't say I'd be real stoked on it. OP might wanna rethink theory as possibly find another lift instead of replacing shocks.
  11. Jun 8, 2013 at 5:58 AM
    Necro
    Norfolk Va.
    97 Tacoma
    Thanks for the help and the suggestions!
  12. Jun 8, 2013 at 11:26 AM
    Necro
    Norfolk Va.
    97 Tacoma
    Now that I know what I have, I've done some searching and found this:
    http://www.nwtoys.com/content/126-trailmaster-lift-inversion-modification.html
    Whitfield seems to know quite a bit about the various conversions and I learned quite a bit here:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/136037-ideas-replacing-bad-6-trailmaster-strut.html
    And here:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/135803-6-dicontinued-trailmaster-lift-help.html
    So now that I know it can be done, and how to do it, what shocks/struts should I look for and what kind of ride quality should I expect? Any brands that are better than others with the IFS set up? Which shock does the most work on the front since there is 2 per side? Is there a way to make them match so they both share equal duty? Or would it be better to have one of them do most of the work and have the other one there just because?
    Edit: Just throwing in some more helpful threads as I find them:
    http://www.ttora.com/forum/showthread.php?t=77908
  13. Aug 1, 2013 at 3:03 AM
    snyper96799
    snyper96799 Well-Known Member
    Yon
    American Samoa
    03 Tacoma lifted
    6inch trailmaster, deckplate, custom halo lights, 18inch sub w/ 3000 watt amp, minor interior mods
    I have that same exact lift on my 03. If your trying to the replace the struts the gabriels are pretty good. I changed them out a couple times already. If its the shocks i still have the old fabtech 2.5 coilover shocks. Most coilover shocks should fit just gotta get the right length. Which i THINK is 8 or so. As for the inversion mod i couldn't get it to work the angle was just not right for me so i just put them back on the normal way.
