I need reassurance on a tire size
Discussion in 'Wheels & Tires' started by DocD, Feb 6, 2019.
  1. Feb 6, 2019 at 7:43 AM
    DocD
    DocD [OP] Well-Known Member
    Mn./SoCal
    09 access cab
    My 2009 4x4 access cab call for 245/75/16 (sticker on the door) tires, although I see 265/70/16 listed as well, the tires I want to purchase are not available in 245/75/16 but are available in the 265/70/16 Question, out side of having to get a different spare, is there anything I should be aware of? rim size? Thanks
  2. Feb 6, 2019 at 7:45 AM
    The_Great_PNW
    The_Great_PNW Well-Known Member
    Luke
    WA
    Current - 2019 DCSB QuickSand Previous -2011 DCLB White
    2011 running 265/75/r16 you'll be okay lad.
    DocD[OP] likes this.
  3. Feb 6, 2019 at 9:00 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    A 265/70R16 is nominally .14" taller than a 245/70R16. It is also nominally .78" wider. Speedometer difference at 60 mph is .27 mph faster than the 245/70R16. None of that is enough to worry about.
    edit= I'm not sure I'd even mess with getting a spare in that size.
  4. Feb 6, 2019 at 11:50 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    As mentioned you will be fine. If we can help you please let us know.
    DocD[OP] and The_Great_PNW like this.
  5. Feb 6, 2019 at 12:46 PM
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    I could use some re-assurance as well.
    Below is a photo of my right rear tire on my 2004 Taco DCSB TRD. I'm pretty sure those are the stock rims. They sure look like the ones here: https://www.partsgeek.com/gbproducts/AC/8221-04030744.html which says they are 16x7.
    Can someone confirm they are 7" wide rims, and I should have no problems mounting 245/75R16 tires as well? (I already know they fit 265/70R16 and 265/75R16.)
    Thx in advance.
  6. Feb 7, 2019 at 4:07 AM
    JNG
    Mount your 245/75R16's. You'll be fine.
  7. Feb 7, 2019 at 6:08 AM
    Discount Tire
    Arizona, USA
    Yes, they are 7-inches wide and you can verify this by looking on the backside of one of the wheels - the wheel should be stamped somewhere with 16x7J.
    Tire size 245/75R-16 is safely run on a 7-inch wide wheel :thumbsup:
  8. Feb 7, 2019 at 6:11 AM
    steve2267
    Colorado
    Thank you guys for the warm fuzzies.
    Thanks DiscountTire for the information about where to look on a wheel to see the size. :cheers:
