I need slider specs!
Discussion in '1st Gen. Tacomas (1995-2004)' started by malander, Jan 26, 2011.
  1. Jan 26, 2011 at 10:18 AM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Hey guys I've been contemplating some sliders for a while and have decided to try and build my own. I know they're going to be about 78" long made of 2x2 square tubing that's either 1/8" or .120 wall. My main design is finished I just don't know what size frame plates and gussets I should use. I wouldn't mind over engineering these as they will be pretty heavy. I'll try and get some pics up on the next couple days but basically imagine demello hybrid sliders except all square tube. Any of these measurements would be a huge help so please let me know what you guys are running. Thanks alot ya'll
  2. Jan 26, 2011 at 12:03 PM
    malander
    max
    01 limited trd 4x4
    Come on guys I know ya have em! If I can get the specs in before 3:00ish I might be able to finish the design today
  3. Jan 26, 2011 at 12:10 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    the frame plates on my sliders are 4" x 4" i believe (i have the demello standard round-tube sliders) and the gussets are just a triangle piece from the edge of the plate to the tube that extends away from the frame.
    i don't have my truck with me here at work today or i would go get exact measurements for you. i can check and reply back when i get home ~3:30 or 4pm.
  4. Jan 26, 2011 at 12:24 PM
    malander
    max
    01 limited trd 4x4
    Thanks alot I think that will help me get this design done today, do you think the gussets would just be about an inch on two sides and 1.414" for the hypotenuse? I can't decide on if that would be sufficient or if I should go with a massive 3x4x5 triangle. I also forgot to mention that I need the length of the legs. Once again thank you
  5. Jan 26, 2011 at 1:11 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    why are you using sqaure tubing?
    that's going to look weird in my opinion
  6. Jan 26, 2011 at 1:27 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    i always over-build when doing projects like this myself, so if it were me, i'd opt for as large a triangle as possible. it's going to be under the truck and pretty much invisible, so why not, you know?
    that said, i think the gussets on my sliders are probably 1.5" - 2" per side (again, i'll have to measure later for actual specs), but i don't recall them being overly large and the sliders are definitely solid and can be used as a jacking point if need be.
    do you plan on welding or bolting the sliders to the frame?
  7. Jan 26, 2011 at 4:05 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    Here are actual measurements:
    Frame mount plates: 4" x 4"
    Gussets: 4" (along the tube) x 2" (along the gusset), but then the top part of the triangle that would overhang the gusset is cut off so it looks something like:
    |________\
    where the gusset is on the left and the tube going out to the sliders is along the bottom.
    the tube attachments to the sliders are roughly 8"
  8. Jan 26, 2011 at 8:38 PM
    malander
    max
    01 limited trd 4x4
    Square is alot easier to measure out and cut angles from whereas with round tubing I would have to get a tube bender and deal with a whole lot more shenanigans than I want to. It's either perfect or complete shut to me and I want to get this done right.
  9. Jan 26, 2011 at 8:45 PM
    malander
    max
    01 limited trd 4x4
    This is a little confusing to me but I'll figure it out when I'm not so tired. They will be welded in the end. So basically your gusset is more of a quadrilateral than a triangle correct? I think I will still be going with a triangle simply because it seems like it would distribute pressure to the frame plate better. I finished the design but it will need some refinement when I take more measurements when it gets a little warmer out. I'll try and post up pics tomorrow. Thanks alot man you've been a great help
  10. Jan 26, 2011 at 8:46 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    If you'd like some of the same gussets and 'L' shape frame plates I use on all my sliders, hit me up. Wrapping under the frame in the 'L' shape adds a lot of beef IMO. My plates are 4" wide and the gussets are a 2x6" right triangle. Slider legs should be about 8" long
  11. Jan 26, 2011 at 8:47 PM
    RelentlessFab
    Eric
    Sparks, NV
    These are CNC waterjet cut from 3/16 plate. :cool:
  12. Jan 26, 2011 at 8:49 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    Take a look at this thread, specifically post #15.
  13. Jan 26, 2011 at 10:53 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    sorry, my little ascii art spacing got a little messed up, but the idea's there. the sentence that confused you is referring to the diagram. so the frame mount plate is along the left edge and the leg going out to the slider is along the bottom of the diagramed gusset.
    looks like relentless has a pretty solid set up there. my mounting plates don't wrap under the frame in an "L" shape, but if i were to build a set myself, i'd most likely go that route for added strength.
  14. Jan 27, 2011 at 6:53 AM
    malander
    max
    01 limited trd 4x4
    I really wanted to make this all by myself but I definitely don't want to skimp out on the mounting points or end up with crooked ass sliders. I think I would have to modify the gussets unless I welded the leg to the bottom of the frame plate and not the center. How much would eight frame plates and gussets cost me?
  15. Jan 27, 2011 at 6:54 AM
    malander
    max
    01 limited trd 4x4
    Thanks!
  16. Jan 27, 2011 at 6:55 AM
    malander
    max
    01 limited trd 4x4
    Thank man, I think I got it now as I said I may order some relentless Fran plates and gussets
  17. Jan 27, 2011 at 6:58 AM
    malander
    max
    01 limited trd 4x4
    Alright guys I probably won't have time to post up picks today but I'll try and figure it out on my iPhone. I will probably extend the main body of the sliders so that they are around 12"-13" from the frame. Legs will be about 8"
  18. Jan 27, 2011 at 6:59 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I would have used round heavy walled pipe onto 3/8 "L" plate steel and weld on frame
  19. Jan 29, 2011 at 9:47 PM
    malander
    max
    01 limited trd 4x4
    heres a quick pick. legs have been redesigned and aren't full assembled in this pick. The orange area looks like it isn't cut out for some reason but it is symmetric to the other end. what do ya'll think? these are 78" but I'm designing some 80" sliders as well. the angle thing has kinda frustrated me, you can't really angle square tube because the legs would be about 2.2" long rather than 2" because of the angled cut (im thinkin about 25 degrees)
  20. Jan 29, 2011 at 10:15 PM
    Nightwar
    Nightwar .....
    Nick
    Webster, Tx
    11 SR5 V6 4X4 Silver
    Avid sliders & Lightbar, Front 5100s/Eibachs, Rear OME Shocks/Alcan 2" AAL, LR UCAs, Debadged, ProComp 7089s, BF Goodrich All Terrain T/A KO, Wet Okoles, Sockmonkey decals, 2x Kicker CompVR 10s, Pioneer P4300DVD, BHLM
    Well I like the angle look. But mine were easy with round tubing. Also got to make sure the door can open. I put my braces on the frame and then adjusted the angle. What your doing right now is the hardest part. An angle with square tubing is tricky.
