I need some help on 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma08brandon87, Jan 16, 2015.
Thread Status:
Not open for further replies.
  1. Jan 16, 2015 at 7:22 PM
    tacoma08brandon87
    tacoma08brandon87 [OP] Well-Known Member
    brandon
    El Paso Texas
    TRD
    Hello guys. Am new to this type of stuff. I wanna do 5100s all way around with coil springs as well. I wanna set them at 1.75 just to match my rear. I have taco lean.
    My ??? To you guys is.. How is the rid?? My friends told me is better ride going with coil springs. Then using your stock ones. Help plz thank you
  2. Jan 16, 2015 at 8:09 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Your stock springs are coil springs. It's going to ride a little stiffer, but in a good way. Running an aftermarket spring with lift built into it will let you run the 5100's in front at zero for no pre load and a better ride.
  3. Jan 17, 2015 at 6:05 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    What year is your truck and is it a 4x4 or prerunner ? Dos it have the 2+1 or 3+1 leafs ? Mine is a 2011 prerunner with the 2+1 leafs and I went with the 5100 set at 0 and the OME 883's and it is level . The ride is awesome . Definitely do the spacer for the driver side lean .
Thread Status:
