I need some help please!
Discussion in '1st Gen. Tacomas (1995-2004)' started by GRITSINFL, Mar 1, 2024.
  1. Mar 1, 2024 at 3:38 PM
    GRITSINFL
    GRITSINFL [OP] New Member
    Sharon
    2004 toyota tacoma prerunner
    I have a 2004 toyota tacoma prerunner. Today I replaced the right side tail light assembly and that's when the issues started. After the assembly was replaced all the sudden the left side did not work and the auto transmission will not shift. Are they related or is it all just coincidental? Thank you for reading and any advice is appreciated.
    Jeffch likes this.
  2. Mar 1, 2024 at 3:49 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    Was this a stock replacement using stock bulbs or is it LED?
  3. Mar 1, 2024 at 4:03 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    If the brake light fuse is blown, the transmission can be locked out as a safety thing
    (source: my celica’s brake light circuit was blown, and would not shift out of park)
    super_white, KdF and GRITSINFL[OP] like this.
  4. Mar 1, 2024 at 4:20 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Welcome to TW!
    Take a breath we need some info.
    Your replacing a stock tail light with a stock tail light?
    Is it the whole assembly or a bulb?
    Some leds can make your truck do weird stuff!
  5. Mar 2, 2024 at 1:30 AM
    GRITSINFL
    Sharon
    It was the whole assembly, the lense got damaged so I went on ebay and bought the whole assembly..
  6. Mar 2, 2024 at 4:12 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Does it have led bulbs in it?
    Is it a Toyota assembly?
    New used?
    You could try unplugging the connectors and see if that cures your trans issues.
    Any bare wires or issues making connections during installation?
    May want to check fuses as mentioned
  7. Mar 2, 2024 at 4:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    Disconnect the new taillight, make sure the fuse is good, then see if you're back to normal shifting and left light working.
    If so you found your problem.
  8. Mar 3, 2024 at 8:13 AM
    GRITSINFL
    Sharon
    Here's an update! i disconnected the new assembly and put the old one in and just used the lense. She's back to her old self. Guess it's true about those little gremlins coming out to play sometimes lol. Thank you all for your advice. Funny how 4 screws and a clip can cause such an issue.
  9. Mar 5, 2024 at 3:37 AM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Glad it’s back I’d say your taillight assembly was the problem.
    GRITSINFL[OP] and Bivouac like this.
