I need some help with my front suspension height please
Discussion in 'Suspension' started by EndlessSummer, Dec 29, 2012.
  1. Dec 29, 2012 at 6:16 PM
    EndlessSummer
    EndlessSummer [OP] Well-Known Member
    Sonora, CA
    So my front suspension consists of bilstein 5100 with eibach coils set at the .85 setting. I also have 3/4" spacers from toytec in there. I installed it today and got 4" on the passenger side and about 3 3/4" on the drivers side. Everything is seated properly and I used threads on TW for the install so I'm pretty sure I did it correctly.
    I decided to try and get a full 3 inches so I bought the 3/4" spacers thinking thats what toytec puts in their 3" bilstein set up. Can anyone confirm the spacer size that comes with that? Or am I wrong?
    Also I guess I'm confused on how to figure the actual finished height. By my calculations bilsteins at .85" with eibachs 1.6" and the 3/4" spacer should give me 3 3/16" of lift. Am I wrong and if so can someone give me a quick run down on how to figure it correctly?
    I also have the .25" spacers which are NOT installed and I may consider putting those on instead because it seems a little high and I don't want to destroy my CV boots and joints. Will the diff drop really help me out? I'm kinda reading mixed reviews on it. Or a Relentless bumper :)
    Thank you in advance for the help
  2. Dec 29, 2012 at 6:34 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    the type of spacer your lookin at does it sit on top of the whole shock assembly between the shock and shock tower?
  3. Dec 29, 2012 at 6:38 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    I believe you'll get twice the spacer height, like 1.5" for a 3/4" spacer. That would bring you to the 4" you're at, which is too high to have good CV angles and other things.
  4. Dec 29, 2012 at 6:44 PM
    EndlessSummer
    Sonora, CA
    you are correct sir the spacer sits on top of the top plate between the top plate and the shock tower. So it would be relatively easy to remove
    That makes sense. Should I put the .25" spacers on instead? Would that give me 3 inches?
  5. Dec 29, 2012 at 6:50 PM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    I'll defer to those here who know more than me, but I think you get 1.6" from the coils, plus 0.85" from the shock setting = 2.45". Add another 0.5" from the 0.25" spacer and you get 2.95" total.
  6. Dec 29, 2012 at 6:52 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    i would avoid the top plate spacers and use the 5100s at a higher notch to gain 3 inches. with eibachs that should be more than enough and if your 4wd you dont wanna go more than 3 inches
  7. Dec 29, 2012 at 6:53 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Yes.
    Now question for the OP are you 4x4? Also first or 2nd gen taco? Dont go above the 3" if 4x4. If first gen the eibachs give 3" by theirselves.
  8. Dec 29, 2012 at 7:03 PM
    P9HST2
    Iowa
    2012 MGM AC TRD OR
    Thanks Chris. Sometimes I forget that all discussions aren't 2nd Gen 4x4 like I have.
  9. Dec 29, 2012 at 7:05 PM
    EndlessSummer
    Sonora, CA
    Sounds like that is about as close to 3" as I'll get. I just want it to sit as level as possible. I'm not a big fan of the rake.
    isn't .85 the highest setting you can go with the eibachs? I guess I could do without the spacer and get a smaller AAL
    I have a 2nd gen (2010) and yes 4x4.
  10. Dec 29, 2012 at 7:13 PM
    nfs257
    DFW
    She gone
    My opinion would be go with the Billies at .85 with the eibachs and do the smallest spacers on the drivers side to compensate the lean. You are looking at about 2.5" of lift at that point.
  11. Dec 29, 2012 at 7:24 PM
    EndlessSummer
    Sonora, CA
    Thank you sir. I think I'll go that route. I'm glad those spaces sit above the top plate. That sketchy ass coil compressor was quite an adventure
  12. Dec 29, 2012 at 7:29 PM
    nfs257
    DFW
    She gone
    I have changed out the springs several times and am doing another set this weekend and never use a spring compressor... :D
    I use a jack under the LCA and the shock tower. I do NOT suggest this unless having done it before or have somebody there that has.
    Although there is a youtube video showing the general idea.
  13. Dec 29, 2012 at 7:37 PM
    EndlessSummer
    Sonora, CA
    haha ya I've seen a few of those videos. I did half of the first one with a 1/2" ratchet before I realized I still had my work tools in the back of my truck and used my dewalt impact for the rest and it worked out great. I thought about trying it that way but this is the first time I've done any work on suspension so I figured I should probably pass haha.
  14. Dec 30, 2012 at 9:02 AM
    EndlessSummer
    Sonora, CA
    ok so I took the 3/4" spacers off and put one 1/4" spacer on the drivers side for the lean correction. both sides are now level but I'm getting a total of 3 3/4" of lift. Does that sound right?
    before measurements ground to fender
    Drivers-34 1/2
    Passenger-34 3/4
    After measurements
    Drivers 38 1/4
    Passenger 38 1/4
    What am I doing wrong? How much will this lift settle?
  15. Dec 30, 2012 at 9:13 AM
    EndlessSummer
    Sonora, CA
    Well I thought the garage was somewhat level but I guess I was wrong. I parked it out in the street and got 37 3/8 for a total of about 2 3/4" of lift. Ultimately I think removing the 3/4" spacers was a good idea. thanks for all the help guys
  16. Dec 30, 2012 at 10:08 AM
    nfs257
    DFW
    She gone
    Also remember when it comes off the jack your suspension isn't loaded. So moving it helped it settle.
