I need some ideas for my shifter!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ER187, Mar 20, 2023.
  1. Mar 20, 2023 at 11:50 AM
    ER187
    ER187 [OP] Member
    Eric
    Pekin, IL
    2022 TRD Off Road Lunar Rock
    Hey all...this is my first post and I'm hoping you guys can help me out. I have a cue ball for a shifter knob with my military units insignia on the top but the gap between the bottom of the knob and the top of the boot is driving me crazy! Any thoughts of what to use to bridge the gap and make it look like its supposed to be there? Any help would be greatly appreciated! I attached a pic so you can see what I'm talking about. Thanks again! shifter.jpg
    HondaGM likes this.
  2. Mar 20, 2023 at 11:55 AM
    gsxrdoug
    gsxrdoug 2009 X-Runner
    Douglas
    Hawaii
    2009 X-Runner
    Stock
    wrap a hair scruncy thingy around it.
  3. Mar 20, 2023 at 11:55 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You could simply get a nylock nut thread it down on the shaft. Then place that plastic clip that holds the boot so it sit on top of It. Then thread the shifter back on and clip the boot up.
    Piece of tubing around the shaft that you can cut to length would work as well. Use the tubing to hold the boot up and the boot will hide the tubing.
  4. Mar 20, 2023 at 11:56 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    Hollowed out piece of carrot
  5. Mar 20, 2023 at 11:56 AM
    ER187
    ER187 [OP] Member
    Eric
    Pekin, IL
    yeah no...lol
    HondaGM likes this.
  6. Mar 20, 2023 at 11:56 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    Mini donut from dunkin
  7. Mar 20, 2023 at 11:57 AM
    Aw9d
    Aw9d That one guy
    Anodized red sleeve to hide it would look good imo.
    HondaGM and gsxrdoug like this.
  8. Mar 20, 2023 at 11:59 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    A piece of conduit
    RIX TUX and HondaGM like this.
  9. Mar 20, 2023 at 12:06 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    That sounds kinda dirty..:eek:
    HondaGM and Lawfarin[QUOTED] like this.
  10. Mar 20, 2023 at 12:06 PM
    ER187
    ER187 [OP] Member
    Eric
    Pekin, IL
    red anodized sleeve would be great! I tried a piece of hose...did not like the look of it. Aluminum sleeve would work.
    HondaGM and Aw9d like this.
  11. Mar 20, 2023 at 12:08 PM
    ER187
    ER187 [OP] Member
    Eric
    Pekin, IL
    actually you know what might look ok....take the top off a turkey baster..cut the round part in half so the knob can sit down in it...hmm. they're only 2.50 at walmart...worth a shot?!
    HondaGM likes this.
  12. Mar 20, 2023 at 12:08 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Use the boot to hide the tubing. Using the tubing to hold up the boot to the shifter
    HondaGM likes this.
  13. Mar 20, 2023 at 12:11 PM
    ER187
    ER187 [OP] Member
    Eric
    Pekin, IL
    I did try and pull it up, but it was pretty tight. Might be my only option if everything else fails to look decent.
    HondaGM likes this.
  14. Mar 20, 2023 at 12:51 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    There isn’t enough boot to stretch all the way to the threads while retaining the stock trim clip.
    I went through this with a knob I really liked, but it also sat too high on the threads like yours does. Especially when in park there isn’t enough boot material to fill that space.
    You could remove the chrome boot trim piece (that you have a black cap on), and it would give you a little more boot to work with. The boot is simply flipped inside out and zip tied on the underside of that piece, so you could do something similar with a rubber gromet and gain a little bit of length.
    You could also get an aftermarket boot that may have more material, I’ve seen several sets (shifter and handbrake) on Etsy.
    Without that cue sitting lower on the threads, like all the way at the bottom, the stock boot isn’t going to cover that gap.
    You could use a grommet to hold the trim clip as high as it will go and use 1/2” heat shrink on the remaining exposed threads
    HondaGM likes this.
  15. Mar 20, 2023 at 12:51 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    I used a piece of padauk to go with the custom olive knob I made.
    Dkurtz42, HondaGM and GarlicFarts like this.
  16. Mar 20, 2023 at 1:06 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    get some heat shrink shit from Home Depot . Blast it with heat gun
    HondaGM likes this.
  17. Mar 20, 2023 at 1:09 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    HondaGM likes this.
  18. Mar 20, 2023 at 1:14 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Find a craftsman, since you’re all in with the cue ball, you need the tip.
  19. Mar 20, 2023 at 1:16 PM
    BillyE
    BillyE Well-Known Member
    Is it possible to just drill that knob out and run a tap deeper?
    Dkurtz42, HondaGM and musicisevil like this.
  20. Mar 20, 2023 at 1:35 PM
    Dschiz
    Dschiz Well-Known Member
    2022 Toyota Tacoma TRD Sport (Super White)
    Factory 2-inch lift kit with Toyota Heritage Grille. Added some heritage color tri-color vinyl to hood and rear.
    Get the casing of a 5.16 upload_2023-3-20_15-33-55.jpgand place in center and trim to fit.
    AM6217, Phlogiston and HondaGM like this.
