I need some pointer on wheels for my truck!!
Discussion in 'Wheels & Tires' started by mstoudt, Feb 15, 2012.
  1. Feb 15, 2012 at 1:51 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    04 tacoma SR5 Double cab
    3 inch suspension lift, 3 inch body lift, 285/75/16 dick cepek fun country II, tinted windows, K&N cold air intake, 16 inch KMC dx series wheels, flowmaster dual exhaust
    i have a 3 inch suspension lift and a 3 inch body lift on my 04' Tacoma SR5 double cab. and im rumming 285/75/16 pro comps. and i only have about a 1/4 inch from my A arm n coil overs n whatnot. and i think need an off set wheel to set me out a little more i only what like 3/4 - 1 inch space from my tire and my A arm and everything. and i want a wider wheel as well like 8 inchs compared to 6 like my stock wheels are. i want nice looking ones that are good quality but i dont want to spend too much.. so what im asking is.. what size wheel do i need and maybe some bands or something to look at ? thanks !
  2. Feb 15, 2012 at 3:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW. Your stock wheels have 4.5" backspacing. So if you find one with, for example 3.75" BS, that will push the tire away from the control arm by 0.75".
    With 285's you should be looking at 8-9" wide wheels.
  3. Feb 15, 2012 at 3:36 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    ok thanks a ton! does that also come in a negative number ? or is it positive ? you have any suggestions on wheels ? or you know any websites that have the size i need i like the ion alloy 174 black and the eagle alloy 185 something along thoses lines. thanks !
  4. Feb 15, 2012 at 4:59 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    and would a -11mm work? how much space do ya think that would bring me out from my control arm ? thanks !
  5. Feb 15, 2012 at 5:08 PM
    KPT
    09 Prerunner
    What is the width of the rim. Backspacing depends in both width and offset.
  6. Feb 15, 2012 at 6:06 PM
    mstoudt
    mstoudt [OP] Member
    michael
    Ridgeley, WV
    16x8 .... im looking at the eagle alloy 185 black and the mickey thompson classic ll black. which ones do you think would work best for what im looking for? and what detentions and what not with all the number ? thanks !!!
  7. Feb 15, 2012 at 6:10 PM
    KPT
    09 Prerunner
    Here is a chart (1/3rd down the page) that will help you convert width and offset to backspacing.
    http://www.rsracing.com/tech-wheel.html
    You should find someone who is running 285s on a first gen and ask what backspacing they have. Browse our 1st gen builds subforum and I'm sure you'll find plenty of people.
  8. Feb 15, 2012 at 6:10 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    16 X 8 Ultra Drifters
    Only had to take off front mudflaps and grinder for about 1/2 inch from inside of front fender wheel well lower corner...this is with new UCA's...
  9. Mar 26, 2012 at 8:36 AM
    DD03SR5
    DD03SR5 Well-Known Member
    Derek
    Ontario,Canada
    03 SR5 4X4
    Deckplate,5100's,eibach's,Wheelers AAL,
    Im having the same problem i have 285 75R16 km2, billys at 2.5 and spidertrack 1.25 spacers and i want the same stance that the spacers give me but evety shop i go to tells me that there srent many rims that will fit! Did you ever get some rims?
