I Need Some Serious HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BullComa4.0L, Mar 21, 2025.
  1. Mar 22, 2025 at 11:01 AM
    BullComa4.0L
    BullComa4.0L [OP] Well-Known Member
    07 4.0l BullComa
    Right on thank you.
  2. Mar 22, 2025 at 11:03 AM
    BullComa4.0L
    07 4.0l BullComa
    Seriously, especially when pressure accumulates within casing.
  3. Mar 22, 2025 at 11:05 AM
    BullComa4.0L
    07 4.0l BullComa
    I looks like tar I think or a grayish color
  4. Mar 22, 2025 at 11:05 AM
    BullComa4.0L
    07 4.0l BullComa
    Out
  5. Mar 22, 2025 at 11:06 AM
    BullComa4.0L
    07 4.0l BullComa
    But I don't hear it coming out of the breather, now to think about it.
  6. Mar 22, 2025 at 12:53 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You have a vent problem not a gasket problem
    Somebody should also pull the brake drums and see if gear oil is leaking at the axle seals too
  7. Mar 22, 2025 at 1:17 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    If you have pressure, the air needs to escape from somewhere. Probably the weakest point. It should be the breather, but if thats clogged, maybe the gasket material, which could be the leaking that you see. Another place could be the axle seals.
    I would replace the breather just for piece of mind. Plus its like $4. Then let the shop reseal it for free, and see if you have leaks after that. Id probably also check the breather hose for kinks
  8. Mar 22, 2025 at 2:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @BullComa4.0L you've got people replying in multiple threads for this same issue. Ask a moderator to possibly combine the 2 threads? The one in the 2nd gen section would probably get more eyeballs on it..
    BullComa4.0L[OP] likes this.
  9. Mar 22, 2025 at 5:08 PM
    Why I oughta...
    Why I oughta... Well-Known Member
    2014 Base AC 4x4 2.7 5speed
    I never did a tacoma 3rd member before. Is that gasket absolutely necessary or could you just use something like the permatex gear oil rtv mentioned in the previous post by it self?
  10. Mar 22, 2025 at 5:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The gasket will help fill in some of the voids and non-flat areas.
    I'd use a gasket AND RTV.
    winkel and XSplicer62 like this.
  11. Mar 23, 2025 at 12:07 PM
    TacoTuesday1
    SD CA
    Threw out my old gasket, cleaned the mating surfaces, and used RTV like in the YouTube videos. No leaks.
    breather reroute and replace done some years ago. Personal preference is two way valve.
  12. Mar 24, 2025 at 6:54 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    The oem gasket is fine, 99.999% of us drive around with a 3rd member sealed by the same gasket that doesn't leak and never has. The shop ether gacked up the sealing surface or didn't seal it properly, simple as that. In that kind of job after cleaning everything well, I'd have coated both surfaces with a permatex sealer and installed the gasket, I'd bet good money it wouldn't leak and there'd be zero drama. There's no trick to it, the job just needs to be done right and the shop didn't do that. Don't over think it, check the sealing surfaces for irregularities, replace and reseal the new gasket.
    XSplicer62 likes this.
  13. Mar 24, 2025 at 11:02 AM
    BullComa4.0L
    07 4.0l BullComa
    Wouldn't I see oil leaking through the drum? It would be all over my wheel right?
    Just asking
  14. Mar 24, 2025 at 11:05 AM
    BullComa4.0L
    07 4.0l BullComa
    Okay. I bought a breather kit. I'm just worried if it will work better then the oem.
    And there is no hose on my breather there is only the cap.
  15. Mar 24, 2025 at 11:07 AM
    #35
    BullComa4.0L
    07 4.0l BullComa
    Okay, idk how to do that. Who is a moderator?
  16. Mar 24, 2025 at 11:25 AM
    #36
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Tell them to get their torque wrench re-calibrated...
    When they look at you sideways, you'll know yet another contributing factor to your repetitive leak.
  17. Mar 24, 2025 at 11:38 AM
    #37
    fatfurious2
    David
    Ashburn, VA
    OEM has the cap at the axle. Probably can still get clogged, which is why you can extend it, with a hose
  18. Mar 24, 2025 at 6:17 PM
    #38
    BullComa4.0L
    07 4.0l BullComa
    Much more air flow right? I mean that's what I think.
  19. Mar 24, 2025 at 7:27 PM
    #39
    fatfurious2
    David
    Ashburn, VA
    I don't see it as more airflow. I see it as moving the breather away from a place that it can get clogged
  20. Mar 24, 2025 at 8:09 PM
    #40
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It doesn't need airflow, it just needs a vent path to atmosphere
