I need straight forward advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ojohnson, Feb 28, 2015.
  1. Feb 28, 2015 at 11:45 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    In the long run... whats 170 bucks? You'll be happier with the Billies.
  2. Feb 28, 2015 at 11:50 AM
    Ojohnson
    Ojohnson [OP] Well-Known Member
    Ollie
    York, SC
    06 Tacoma DCLB TRD Sport 4x4
    Replaced OEM lights with LED's for the following: MAP, Dome, License plate, and reverse lights.
    You guys are right, Billies it is. You TW guys are good at what you do lol. I'm convinced it's worth it.
  3. Feb 28, 2015 at 11:52 AM
    Ojohnson
    Ollie
    York, SC
    Now that I'm adding Billies I need to start doing more research on them. Anything I should know off the bat? And what the maximum lift achievable with Bilies in the front and nothing in the back without getting too unlevel
  4. Feb 28, 2015 at 11:59 AM
    Ojohnson
    Ollie
    York, SC
    I didn't really plan on doing anything to the back. I've heard that just adding a couple inches in the front and leveling the truck gives it the more aggressive look Im going for. Remember I'm just doing this for cosmetics
  5. Feb 28, 2015 at 12:26 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    You probably learned to "like the way a taco sits up a tad higher in the front" because you have no choice, as long a you have the weak, saggy, brittle stock rear suspension. That's the first thing i would replace before, spacers, shocks etc. To do otherwise would be like building a house on a weak flimsy fondation.
  6. Feb 28, 2015 at 1:47 PM
    Rotnik
    Rotnik Well-Known Member
    Connecticut
    13' TRD OR AC V6 6MT - In spruce
    This......if you have to wait a little longer to save the coin it will be worth it if you plan on keeping your truck for any length of time.
    Plus with the adjustable fronts you could go even higher down the road if you get the funds/ambition to lift it a little more and/or get bigger tires.
  7. Feb 28, 2015 at 2:02 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    The rear springs suck yes, but OP said he uses it as a DD and that's it.
    With the 5100's setting them at .85 or 1.75 will bring you closer to level. I'd personally set them at .85 and keep just a little rake.
  8. Feb 28, 2015 at 2:07 PM
    Ojohnson
    Ollie
    York, SC
    Ok thanks for all the advice what is .85 vs 1.75? Does the new my front end will only be lifted .85 of an inch or 1.75 inches? And what's so bad about the rear? Agin this is a daily driver and as it stands now I love the ride quality that I have. Not that I know any better but I'm fine with my current quality I just want my truck to sit a little higher because I think it looks better.
  9. Feb 28, 2015 at 2:10 PM
    Ojohnson
    Ollie
    York, SC
    Ohhhhh...So how much can I lift the front without it sitting too uneven with the back?
  10. Feb 28, 2015 at 2:20 PM
    Dirtbager
    Dirtbager Member
    High Dez
    2016 Tacoma 4x4 SR5 Automatic
    I have the Bilsteins at one notch down from the highest setting and the truck looks and rides good. I vote no spacers. It's well worth the little extra in install cost to do the shocks.
  11. Feb 28, 2015 at 2:50 PM
    teneighty
  12. Feb 28, 2015 at 3:30 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Why is it that you get more lift than the .85 & 1.75 on the settings?
