I Need Suspension Lift Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TKIV, Jun 25, 2019.
  1. Jun 25, 2019 at 7:54 PM
    TKIV
    TKIV [OP] Well-Known Member
    Thom
    Nashville
    2018 Tacoma Off Road
    Premium Package
    The more I read the more confused I get. My thoughts for now are as follows:
    Guardrails: This is my daily driver and I want more aggressive tires while balancing drivability and fuel efficiency as it will spend 95% of its time on the highway (I commute 2 hours per day all hwy). That said, I want to have off-road capability when fun is required.
    Truck: 2018 Tacoma Double Cab Off Road, totally stock.
    Looking for your expertise but this is my current thought process.
    -265/75/16 K02s - C load
    -Billstein 5100s all around
    -OME Springs (open to Eibach or others - I know it sounds trivial but I like the look of non black coils)
    -Rear leaf pack (unknown size)
    Outstanding Questions:
    1-What amount of front and rear lift do I need to maintain factory rake? If I run 2 in up front from the coils, what size rear leaf pack do I need to make sure I don't look silly towing (personal preference don't light me up).
    2-Which coils are best for a soft daily driver? Again, off-road capable but my preference is for the best ride possible.
    3-If I'm running a 2 in lift do I need UCAs? What are the benefits/detractors?
    I have a flexible budget, not that I want to spend King money, but I also want to balance getting the best for my dollar and don't mind spending more to make sure its right for my needs.
    Thanks for the help fam, looking forward to your mentorship!
  2. Jun 25, 2019 at 8:11 PM
    AZF1504x4
    AZF1504x4 Well-Known Member
    It’s perfect the way it sits...nothing you do to it will make it perform significantly better off road, it may look cooler and that’s probably what you’re after. Which is fine also :wave:
  3. Jun 25, 2019 at 9:52 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    You do not NEED a lift. You WANT a lift.
    -265/75/16
    Your list looks fine. I think the Bilstein 5100 rear shocks only allow one inch of lift. You might consider the 5160 even with that, you only get 1 1/2"
    TKIV[OP], whatstcp and Rockefelluh like this.
  4. Jun 25, 2019 at 9:54 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    If OP gets a leaf pack the 5100s will be able to get 2 inches. Dakar mediums are 2" at 0 lbs in bed and Dakar heavies are 2" at 660 lbs in bed (all with 5100s).
    TKIV[OP] and 9th[QUOTED] like this.
  5. Jun 25, 2019 at 10:12 PM
    tcjacado
    tcjacado Well-Known Member
    Bilstein offers 3 shock options for the rear.
    0 to 1 inch
    1.5 to 3 inch
    And 3 to 5 inch.
    El_Rocinante and TKIV[OP] like this.
  6. Jun 25, 2019 at 10:17 PM
    .223Taco
    .223Taco Well-Known Member
    Austin, Tx.
    '18 Cement DCSB OR
    Watching. Kinda in the same boat. Been leaning toward 5100's
    TKIV[OP] likes this.
  7. Jun 26, 2019 at 7:47 AM
    Ryan at Eibach
    Ryan at Eibach Well-Known Member Vendor
    The Eibach kit will get the job done. Rides great on road and performs off-road.
  8. Jun 26, 2019 at 9:03 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Have you found that specific tire size in C load? I tried finding it before and I couldn’t find it. Just wanted to mention that in case you haven’t found them already. They may be available now though but when I was searching I couldn’t find them in C in that size. 265/70/17 yes but not 265/75/16.
    https://www.tacomaworld.com/threads/265-75-16-c-load-bfg-k02.544488/
  9. Jun 26, 2019 at 10:04 AM
    TKIV
    Thom
    Nashville
    Premium Package
    So I found a pair on Discount Tire last night in 265/76/16 that was listed at $188 per tire, which was quite a bit cheaper than the e rated version. I assumed it was a C load. I still have them in my cart but I cant click on them or find them with the search function now?
  10. Jun 26, 2019 at 10:06 AM
    TKIV
    Thom
    Nashville
    Premium Package
    Ryan, what size rear leaf pack would I need to keep the factory rake with a 2 in lift on the front?
  11. Jun 26, 2019 at 10:54 AM
    Whitetail Assassin
    Tedric
    West Virginia
    Not sure man. I just haven’t see the C in that 16” size but I haven’t been actively searching recently either. You can either go E load (though it’s kind of overkill) or maybe step up to a 17” or go with a different brand if you don’t want E or to go to a 17”.
    TKIV[QUOTED][OP] likes this.
  12. Jun 26, 2019 at 2:23 PM
    Ryan at Eibach
    You'd probably need an inch.
    71tattooguy and TKIV[QUOTED][OP] like this.
  13. Jun 27, 2019 at 10:33 AM
    TKIV
    Thom
    Nashville
    Premium Package
    This looks sharp! For the rear, did you get 1 or 1.5 inches from the Dakars?
  14. Jun 27, 2019 at 12:22 PM
    Tacoma_SR5Pro
    Tacoma_SR5Pro Well-Known Member
    '16 SR5 Pro
    These are great suggestions for SHTF situations!
