I need this ride lower
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justmyride, Oct 19, 2017.
  1. Oct 19, 2017 at 6:24 AM
    justmyride
    justmyride [OP] New Member
    ray
    2012 Tacoma prerunner 4.0
    Texas Edition 17" wheels
    How do I lower this ride. Also does tire design (style) change the ride. My taco has 150k and the ride a little rough.
  2. Oct 19, 2017 at 6:50 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    Welcome to the forum....
    and I'm not sure what you mean about "lower this ride"
    if you mean physically lower the truck:
    https://www.google.com/search?q=tac...x6fzWAhVmqVQKHYCzCR0QsxgIKQ&biw=1915&bih=1031
    if you mean "making the ride a little less harsh".... you can get better shocks / struts, and buy Michelin tires.
    MT tires < All Terrain < Street tires as far as ride quality
  3. Oct 19, 2017 at 8:40 AM
    justmyride
    ray
    My truck sits up high like it's a 4wd, it's probably 6" higher then a normal (regulator) prerunner. I can't figure out why it sits so high, only see a 1 inch space under rear axle (side note: both front seats have 1.25" spacer between rear bolts and frame) the shocks & struts appear longer than standard OME.
  4. Oct 19, 2017 at 8:41 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Pictures of suspension
    TacoCat and scottalot like this.
  5. Oct 19, 2017 at 8:44 AM
    Pigpen
    Dan
    Northwest Montana
  6. Oct 19, 2017 at 9:04 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
  7. Oct 19, 2017 at 10:48 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Nobody can help you here unless you post pictures.
  8. Oct 19, 2017 at 10:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You could also remove the spacers under the seat...
    ChadsPride likes this.
  9. Oct 19, 2017 at 10:59 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Buy a xrunner?
  10. Oct 19, 2017 at 11:00 AM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Remove everything that is making it higher?
    blu92in99, Fitz235 and EatSleepTacos like this.
  11. Oct 19, 2017 at 11:10 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
  12. Oct 19, 2017 at 1:10 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Your going to fit right in around here....
  13. Oct 19, 2017 at 3:26 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Those are just phone books to sit on.
  14. Oct 19, 2017 at 3:30 PM
    tcjacado
    tcjacado Well-Known Member
    We need this here and welcome to TW!
    Need pictures of said Hawaiian lift?
