i need tips on how to lube that u-joint in front of transfer case..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Dec 31, 2009.
  1. Dec 31, 2009 at 5:28 PM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    ok, i ran out of light, so i gave it up. new year's eve is calling, and i have bubbly to chill.
    but tomorrow, i will attack it with renewed vigor. hahaha. so any tips? come at it from the top? sides? i cannot get the grease hose to seat. i actually ran out of grease on my last attempt, but just squeezing it all over the place, except into the zerk. help?
    cliff
  2. Dec 31, 2009 at 7:35 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    it is not easy to do, i dread every time i do it. i get it between the top and side. if you have a heavy duty grease gun end it might not fit. need the cheap end.
  3. Jan 1, 2010 at 5:51 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    The end of my grease gun can be loosened by turning it a little and that helps get it on there. Hold it tight, be patient and expect failure a few times, but it can be done.
  4. Jan 1, 2010 at 7:05 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    greasing the u-joint is only required for 4x4 tacos correct?
  5. Jan 1, 2010 at 9:16 AM
    aficianado
    back to bone stock.
    i lubed my neighbors regular cab, 2by.
    i will disconnect the hose to take the weight off of it. good tip/idea.
  6. Jan 1, 2010 at 9:57 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Correct. Even if you wanted to, the PreRunner's u-joints are sealed and cannot be greased.
