I need to know if this tire will fit!
Discussion in 'Wheels & Tires' started by tacoma777, Jan 17, 2012.
  1. Jan 17, 2012 at 1:47 PM
    tacoma777
    tacoma777 [OP] Member
    wisconsin
    06 SR5 4x4 TRD Sport
    Will a 285/75/16 or 275/70/17 fit on my double cab 4x4 06 tacoma? Either one? Stock height! PLz advise as any help would be appreciated! Thanks Aaron
  2. Jan 17, 2012 at 1:48 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW. Do you have a 3" lift and wheel spacers? If not, then no on the 285. The 275 you can run without spacers but will still need a lift I believe.
    Also, for future reference, we have a wheels and tires subforum. And this is one of the most commonly asked questions on the site, so the search button is your friend.
  3. Jan 17, 2012 at 1:50 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Aaron , I have 275/70/17 Hankook ATm's , but as KPT mentioned I have a 2 1/2" lift up front and aftermarket UCA's
  4. Jan 17, 2012 at 1:54 PM
    tacoma777
    wisconsin
    so 265/75/16 is the biggest i can go stock
  5. Jan 17, 2012 at 1:56 PM
    Large
    Large Red
    Correct. Or 265/70/17
  6. Jan 18, 2012 at 8:39 AM
    tacoma777
    wisconsin
    ok, Im ordering the general grabber red letter tires! So , that being said i am buying the TRD 16" 7.5 10mm offset bead lock wheels. With this set up will i be able to go with 285/75/16 at factory height or is 265/75/16 my biggest option at factory height?? Thanks so much for any help! Aaron
  7. Jan 18, 2012 at 8:52 AM
    KPT
    09 Prerunner
    265/75/16 regardless of the wheel specs.
  8. Jan 18, 2012 at 9:30 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    Not that you asked but I see you're in WI. IMHO you might want to rethink getting the red letters if you're staying in WI. They're not the best on snow and were never designed to be. You could try having them siped I suppose.
    Like I said, just my $.02.
  9. Jan 18, 2012 at 10:56 AM
    tacoma777
    wisconsin
    ok ok , LOL~! Just want a bigger tire with out a lift. So 265/75/16 it is. Ya, the red letter grabbers are a month out anyway and I have decided to switch tires. Thanks for the 2 cents. It all helps! Im the General Manager of a new car store here in wi so I know my cars well. But I know my sprorts cars well. Not the trucks and what not! Thanks Again! Anyother 2 cents on tire selection is welcomed! Also is the TRD wheel bead lock a good wheel to go with?
  10. Jan 18, 2012 at 11:11 AM
    SubFrozen
    SubFrozen r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    I'm not sure about the wheel bead lock. I highly suggest the Cooper STT's. I've had them in the past and they did amazing in MOAB and through snow (you won't worry about this for the first season you have them). I'm ordering a new set to put on the truck. If you want to go bigger for your tires, get a deeper offset for your rims and swap out your front bumper or remove the plastic lining from your stock one (and maybe some cutting on the end of the bumper itself).
  11. Jan 19, 2012 at 12:13 AM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    They came equipped on my T/X Pro. I love the looks of them but they are not a true bead-lock. It's just a ring on the outside of the wheel to give them the look. The only complaint I have with them is the ring/wheel combo acts like a "cup" and always gets packed with mud or snow. It's a rough ride until you get it all cleaned out. But they choice is up to you. :)
  12. Jan 20, 2012 at 6:58 AM
    tacoma777
    wisconsin
    Huh, well I would think I could leave the ring off maybe? Might look good?? Oh, FYI , 275/70/17 BF AT does fit at factory height! Barely but it's fine! I have a set of brand new BF'S that size and they worked! I'm still gonna switch to the TRD 16" wheel but if anybody wants to know they do fit that big at factory at least. BF does anyway! Thanks Aaron
  13. Jan 20, 2012 at 7:39 AM
    tacoma777
    wisconsin
    Also, based on the fact that my 275/70/17 do fit. Wouldn't be reasonable to assume with the TRD 10mm off set, which I believe will make the wheel stick out further from the control arm then the factory wheel. Is it safe to say I could go to a 285/75/16 tire with that wheel that pushes it further away? I am talking with a 2" lift. The guys at toytec told me a 285 will rub the control arm. But that was a factory wheel we were talking about! I'm not putting spacers on my truck! Any thought???
  14. Jan 21, 2012 at 12:11 PM
    Blueberry
    Nick
    Newton, KS
    Hmm. 285's are pretty wide. I'm interested myself if they'll fit. Right now I'm researching tires for the "bead locks" with future 5100's and I have a feeling 275/75 16 is about all I'd be able to get away with without trimming and new UCA's.
  15. Jan 21, 2012 at 1:01 PM
    OZ-T
    Peter North
    British Columbia
    No rub on the factory UCA's ?
  16. Jan 25, 2012 at 7:52 AM
    Jholder70
    Jholder70 Well-Known Member
    Iowa
    2012 TRD Sport V6 Silver
    Still trying to decide...
    So the 275/70/17's fit, no rub, bo trimming? I was under the impression that the largest I could get without trimming or lift was 265/70/17?
  17. Jan 25, 2012 at 8:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Me too... :mindblown:
  18. Jan 25, 2012 at 8:25 AM
    OZ-T
    Peter North
    British Columbia
    Ya , no turning allowed
    FYI , TW member Teamfast has 275/70/17 with a lift , but stock UCA's and he rubs the UCA at full lock
    If you are at stock height and flex your truck at all and plan on turning , stick to 265/70/17
  19. Jan 25, 2012 at 8:27 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    search..some 275/70/17s fit on stock rims and do not rub UCAs
  20. Jan 25, 2012 at 8:29 AM
    Pugga
    Massachusetts
    F-150 Mod
    Makes sense. So 275/70R17 will fit if you drive in a straight line, will look great at the mall, just avoid flexing on the curbs, 265/70R17 for full articulation of the suspension and tight u-turns :D
